technicolor tg582n need firmware upgrade
- technicolor tg582n need firmware upgrade
11-08-2013 2:20 PM
Re: technicolor tg582n need firmware upgrade
11-08-2013 3:01 PM
09-11-2013 10:07 AM
I have a Linux computer and remote upgrade might be the only way for me
@Plusnet - please say what info you need to upgrade my firmware remotely?
Do I need to change any setting on my browser configuration page to give you access?
Do I need to backup in case the upgrade fails?
Do I need to disconnect my devices from network first?
Cheers
09-11-2013 12:00 PM
It's possible (although not simple) to update the firmware via TFTP. There some info here http://beusergroup.co.uk/technotes/index.php/Modem_Firmware
Quote I have a Linux computer and remote upgrade might be the only way for me
09-11-2013 12:23 PM
MrW, thanks - I'll look into it
09-11-2013 12:40 PM
Woah! Way beyond my geekability (I'm newish to Linux)!
Will borrow a friend's Windows box sometime or maybe Plusnet will respond?
Hello Plusnet, @_Adam_Walker_, @Chris, @Matt Taylor, any staff member, can I get a remote firmware upgrade please?
09-11-2013 1:10 PM
09-11-2013 3:35 PM
Thanks again MrW Glad there are helpful ppl around like you
09-11-2013 4:10 PM
Please CANCEL my firmware upgrade request. I have used a friend's Window computer to upgrade.
Repeat: I do NOT need a firmware upgrade. This has been done already, thanks.
09-11-2013 4:26 PM
mine is
Product Name: TG582n
Software Release: 8.4.4.J
09-11-2013 5:09 PM
http://products.plus-payh.co.uk/firmware/
My modem is the one without the USB port, and I'm on ADSL, so it's 10.2.2 B
My gripe is the flashing program is only available for Windows XP and 7.
Windows 8 has been out for over a year yet still ignored by Plusnet - why???
I used a Windows 8 box but had to fiddle with the compatibility mode first.
09-11-2013 5:15 PM
09-11-2013 5:25 PM
Quote from: acuvic There are several "latest" versions for the tg582n! Here's the link to choose:
that's doesn't help narrow it down then as there are 2 ADSL non-USB ones listed there
Plusnet - ADSL - TG582n-PS (without USB port) - 8.4.4.J
Plusnet - ADSL - TG582n-PS (without USB port) - 10.2.2.B
09-11-2013 5:28 PM
09-11-2013 7:40 PM
is there a slightly different version or something?
