technicolor telnet CLI command for system uptime
MikeTodd
Is there a telnet CLI command to list the uptime since the router was last restarted?
(I know it is available via the UI but I want to find the timne when the UI is not functioning)
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: technicolor telnet CLI command for system uptime
I think:
syslog msgbuf show
May do the trick?
Chris Pettitt
Cloud Environments Engineer
MikeTodd
Thanks - that will do. (Does not give the time itself but does show when last booted, as far as I can see)
Take a look here http://npr.me.uk/scripting.html
Dan.
