syncing down
- Re: syncing down
syncing down
20-04-2008 10:35 PM
hello
can anyone explain why my syncing is down from 6 mbps to 3.2 mbps
it happened after my line was taken down by a lorry and a new one was replaced by bt.
Message 1 of 3
(926 Views)
2 REPLIES 2
Re: syncing down
20-04-2008 10:50 PM
Either you profile has dropped as BT thought there was a fault or they have put in a new cable which isnt joined properly or its on another pair which has more noise or it goes a long way round to the exchange.
Do a bt speedstest to find your profile and post before and after stats. If its your profile then it should build back up again in a few days
Message 2 of 3
(279 Views)
Re: syncing down
20-04-2008 11:14 PM
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 3000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 3680 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 2724 kbps
i had two separate lines coming into the house they have encased the two in one cable i have lost 3000 kbps
Message 3 of 3
(279 Views)
