sync speed
- Re: sync speed
sync speed
20-11-2007 4:02 PM
bt have set my maxdls sync speed at 2500kbps. My modem is showing that it is at 3872 Kbps if i keep achiveing this speed what will bt set my sync speed at will it be same or will they rise it to 3000kbps.
Basicly just wondering how bt set there sync rates to what we actually get on r modems
Message 1 of 4
(1,171 Views)
3 REPLIES 3
Re: sync speed
20-11-2007 4:14 PM
If you stay synced at that speed for the next 3 days your profile should uplift to 3500kbit/s.
Hope that helps,
Hope that helps,
Message 2 of 4
(356 Views)
Re: sync speed
20-11-2007 4:39 PM
A bit optimistic there, the sync speed needs to reach (and maintain) 4000kbps for the IP Profile to be set at 3500kbps. For 3872kbps IP Profile will be 3000kbps.
David
Message 3 of 4
(356 Views)
Re: sync speed
20-11-2007 8:51 PM
cheers for your replys just checked sync speed and its gone up to 3000kbps
Message 4 of 4
(356 Views)
