sync speed went from 6166kbps to 3335kbps WTH
- sync speed went from 6166kbps to 3335kbps WTH
12-10-2013 6:58 PM
Re: sync speed went from 6166kbps to 3335kbps WTH
12-10-2013 7:03 PM
13-10-2013 8:10 AM
13-10-2013 9:40 AM
13-10-2013 10:47 AM
13-10-2013 6:42 PM
13-10-2013 6:56 PM
Modem state: up
Up time (Days hh:mm:ss): 0 days, 1:33:55
xDSL Standard: ITU-T G.992.3
xDSL Annex: Annex A
Noise Margin: 11.4 dB
Bandwidth: 3335 kbps
Attenuation: 52.0 dB
Power: 0.0 dBm
Errors:
FEC: 0
CRC: 10
HEC: 9
Failures since last reset:
LOF: 0
LOS: 0
LPR: 0
ES : 10
13-10-2013 8:47 PM
G992.5 is ADSL2+
13-10-2013 8:57 PM
This is normal for longer lines.
14-10-2013 8:44 AM
Are you plugged in to the master socket, using a single filter without any extension leads in place?
You're definitely provided on the 21CN platform, your upstream speed shows that, however as others have said your router has detected that it's better for your line to work at ADSL2 rather than ADSL2+.
14-10-2013 5:15 PM
15-10-2013 5:17 PM
17-10-2013 11:30 AM
Looking at that though it seems Fibre is now available for you and the estimated speed for that is much better - I guess the cab is much closer to you than the exchange is
18-10-2013 3:42 PM
18-10-2013 3:46 PM
plus the openreach website shouw that my exchange is coming soon, so were did you look to see that i can get fiber
Fibre optic broadband is estimated to be in your area between October 2013 and March 2014. Please note that these dates have been provided by our supplier and are estimates. Dates may be subject to change due to factors outside our control such as; delays agreeing cabinet locations with your local council or unforeseen issues encountered during the construction of your street cabinet.
the fiber cab is there but there is no sticker on it saying that its live, i live about 10seconds walk away from the cab and should get about 76.8mb down and 20mb up
