swapped from BT to PLUS SPEED issue
screwballs
hi there, before we swapped we had bt broadband and used to SYNC at 6240, also think was adsl2 as upload sync was more than 448
but now we have transfered to plus it is slowly geting slower and slower, to around 2848 and 448 up
the line length is 48db
for 2 years it worked fine with bt and after switching it has slowly got slower and slower in 3-4 months
regards
Fixes: 62
Re: swapped from BT to PLUS SPEED issue
Something is really wrong
Can you post your full router stats
screwballs
hi sorry about the late reply, its evan worse now
just restarted the router this saturday morning at 7.50 am and sync is a little higher but notice high sn margin
ptime: 0 days, 0:36:03
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3.296
Data Transferred (Sent/Received) [MB/MB]: 4,78 / 107,39
Output Power (Up/Down) [dBm]: 12,5 / 18,1
Line Attenuation (Up/Down) [dB]: 26,0 / 46,5
SN Margin (Up/Down) [dB]: 23,0 / 15,2
can someone please help with this.
thank you
Fixes: 62
Your default noise margin has progressively increased and is now 15dB which would explain the reduction in download speed.
Judging by the upload speed you are either on 21CN ADSL1 or on 20CN - can you check if your exchange is 21CN enabled http://usertools.plus.net/exchanges/
Are you aware of frequent disconnections and is there any noise on the line - dial 17070 option 2
When you moved to Plusnet did you keep your BT router or did you get a new router from Plusnet
It is possible that a filter is failing - have you made any changes in your property
Fixes: 10
Also have you anything (e.g. phone, alarm, Sky box) plugged in to any other telephone socket which is not connected via a filter?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Hi screwballs,
Welcome to the community forum Smiley
It looks like the noise on your line is the cause of the shortfall in your download speed, I'd suggest trying an alternative microfilter and also try with nothing else connected into your socket. If there is no improvement then I can place a SNR reset that will hopefully resolve this providing everything is OK internally.
Regarding your upload speeds, I can place a modify order to uncap this at it is currently set to 448kbps.
Let me know how you get on and if you would like your upload uncapping.
Chris
screwballs
hi chrispurvey, please could you reset the snr and also raise the upload.
the line is 21cn and we pay for extra broadband.
we have changed the filter and done some tests as below...
Link Information
Uptime: 9 days, 3:18:58
Data Transferred (Sent/Received) [GB/GB]: 1,34 / 1,21
Output Power (Up/Down) [dBm]: 12,5 / 18,2
SN Margin (Up/Down) [dB]: 23,0 / 15,4
12/11/12 reset 11.25am with different filter and everything around the bt socket and router unplugged
Link Information
Uptime: 0 days, 0:01:52
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3.584
Data Transferred (Sent/Received) [kB/kB]: 22,20 / 16,97
Line Attenuation (Up/Down) [dB]: 26,0 / 47,0
SN Margin (Up/Down) [dB]: 24,0 / 15,6
everything plugged in with new filter
Uptime: 0 days, 0:01:22
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3.552
Data Transferred (Sent/Received) [kB/kB]: 41,61 / 18,32
Output Power (Up/Down) [dBm]: 12,5 / 18,3
SN Margin (Up/Down) [dB]: 24,0 / 15,7
thank you
I've placed the order to uncap your upload and this will complete tomorrow. Although your router is showing an uptime of 9 days, there has been several disconnections over the past few days, so placing a SNR reset could make things worse at the moment. If you have been causing the disconnections then I'd suggest leaving your router turned on and we can monitor the connection and review in the morning.
If you haven't been doing and disconnections then I'd suggest raising a fault at http://faults.plus.net so we can investigate it from there.
screwballs
thank you for that and yes i caused the 3 drop outs today, i will make sure the router stays on until tomorrow afternoon and we havnt caused any other drop outs that im aware of as power etc has been left alone always turned on.
thank you for your time
No worries....I'll check over on your connection in the morning and see how it is going.
screwballs
hi the upload is much higher now at 800 thank you, also i think its dropped out again
The connection is definitely dropping still:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image1352811426161.png" />
I'd guess that the regular seeming drops in the early morning might coincide with your heating coming on? Unfortunately though those drops will prevent the line from settling at a good speed if we do reset the SNR so that wouldn't be a good idea at this stage. I'd recommend turning the heating on and off a couple of times and seeing if that affects things?
screwballs
thats strange the only thing near the master socket and router is a fish tank.
is it still dropping now?
Fixes: 24
It does not have to be near the master socket as the problem, whatever it is, can be transmitted over your mains wiring.
Fixes: 54
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13529922718989.png" />
The issue still seems to be prevalent. Central heating or security lights are definitely the most common cause so if possible I'd suggest manually turning off either of those (or both if you have them) at a certain time, just reply back here when you have and we should then be able to see if that's triggered a disconnection.
 Adam Walker
