sudden speed problem on normally fast line
This has been for about 12 hours now.
This line normally support 6.5MB+
I've tried gateway hopping, but the BT speedtest does indicate a profile problem.
Can something be done quickly ?
thanks
BT Speedtest:
Download speedachieved during the test was - 910 Kbps
For your connection, the acceptable range of speeds is 400-1000 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 832 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps
mybroadbandspeed:
Today 10:34 971 kbps (121kB/s) 396 kbps (49.5kB/s)
Today 10:15 967 kbps (121kB/s) 516 kbps (64.5kB/s)
Exchange Status CheckerResults:
Virtual paths: Green
Stable Rate:
Estimated line speed: Not recorded (service activated before we introduced estimates).
Current line speed:  7.15 Mb
From Thomson TG585 v7 Router:
DSL Connection
Uptime: 0 days, 0:09:26
Bandwidth (Up/Down) [kbps/kbps]: 832 / 8,128
Internet
Type: PPPoA
Uptime: 0 days, 0:09:20
IP Address: 87.xxx.xxx.xxx
Data Transferred (Sent/Received) [MB/MB]: 1.89 / 7.28
Re: sudden speed problem on normally fast line
Something has caused a low synch event, and your BT IP profile has dropped to 1000. If you stay synched at 8128, the IP profile should climb to 7150 in a matter of hours.
Whatever you do, don't reboot your router...
jojopillo
HI paulh,
Jaggies is right. Although with an increase from 1000k to 7150k this should be in about four hours.
Jojo Smiley
cheers dears
but over 4 hours now and still stuck
(I have raised a ticket)
this is going to make tonight's flickr upload  a  bit tedious ...
22 hours on and no change, all stats as remain as in my ffrst post and I'm still stuck with sub-1MB speeds.
Not much from CSC either ...
[quote="CSC"]Thank you for your query regarding the speed on your line. Running a line check shows that your IP Profile may be stuck on 1Mb. I have requested that the Faults Team investigate the issue.
Surely after all these years it can't be beyond the wit of PN or BT to fix these issues quickly? It's not as though it's a rare occurrence ...
[rolls eyes, drums fingers, eats toast]
Do bear in mind it's a Bank Holiday today. Not sure if DCT staff are working or not.
Ah but it wasn't a BH yesterday
48 hours on, still stuck at sub-1MB speeds, despite stable rate still saying 7.15 and sync at 8128 ...
ticket #42085453, also raised 48 hours ago
last response from CSC
11:44am, Saturday 30 Apr 2011
I have now initiated SNR reset on your line which should increase the profile on your line in next 48 hours. Please retest this in 48 hours and let us know if you require further assistance.
Well, 48 hours on again, and I'm still stuck on 1000K ...
I have disconnected session and reconnected (without rebooting router so DSL session & therefore sync unchanged)
No change in sync rate (8128/832) and no change in stable rate (still reported as 7.15M)
4 days of substandard speed  ....
jojopillo
Hi paulh,
Is it still the same?
Jojo Smiley
thanks for coming back (I know the forum is not an official support channel)
The problem is resolved now, but it has taken far too long ...
 Download speed achieved during the test was - 6392 Kbps
For your connection, the acceptable range of speeds is 1200-7150 Kbps.
IP Profile for your line is - 7150 Kbps
