sudden speed drop - not happy
- Re: sudden speed drop - not happy
07-01-2015 8:47 PM
from yesterday we have had a sudden drop in speed from being stable at between 6-7mbps down to 1.5mbps for the last couple of days, BT speedtest says that the line is capable of 8mbps and my router gives the following results which suggests the line is good but running speedtests give 1.5mbps download, Please can someone take a look and get it back running as it should
UP DOWN
Current Rate (Kbps) 448 8128 Kbps
Max Rate (Kbps) 1284 10496 Kbps
SNR Margin (dB) 26 14.4 dB
Line Attenuation (dB) 2 5.7 dB
Errors (Pkts) 0 0
UP DOWN
Errors (Pkts) 0 0
Message 1 of 5
(859 Views)
4 REPLIES 4
08-01-2015 3:17 PM
Hi and welcome to the forums,
I cannot see any problems with your account. Please ensure you are using a wired connection for testing, and also reboot the router (after you've logged into it to disconnect).
Tony
Tony
Message 2 of 5
(526 Views)
10-01-2015 8:48 PM
I have been using a wired connect, And am experiencing problems again, tonight we are getting under 1mb download speeds and for the last week they have been regulary below 2, the only day where I saw speeds close to normal was when you replied saying you could not see anything wrong.
also getting stupidly high pings of over 200ms which I have never experienced before
Message 3 of 5
(526 Views)
12-01-2015 3:06 PM
We need to know if the sync rate changes. Your line stats at the time of the problem will give us those answers. Please get us the line stats at the times of the problem, along with a throughput test (www.speedtest.net) and we'll be able to advise further. You can also raise a fault report at faults.plus.net .
Message 4 of 5
(526 Views)
12-01-2015 3:08 PM
Just to add, the details required are in OldJim's sticky at the top of the page.
If raising a fault report, we'll need the results from the BT test site at http://www.speedtest.btwholesale.com/ .
Message 5 of 5
(526 Views)
