sudden service change
gruf69
what the heck have you guys been doing all of a sudden d/load speed hitting just under 20 mbs with a upload speed of 1 meg and a ping time of under 5ms.... what ever youve done keep it up ive never had such good speeds or such a stable line so thanks
Re: sudden service change
It sounds like your exchange & line has just been put on to 21CN, after languishing on 20CN.
This basically means you're now on the Upto 20Mb product and not the Upto 8Mb product.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Acassim
You've hit the nail on the head Avatastic!
@gruf69 - Your connection was upgraded on the 15/09/14 so you're now on the upto 20mbps service with an uncapped upload speed!
