sudden lack of streaming capability.
DunMcH22
I've always had a decent broadband speed (12-15Mbs) and often stream HD movies from Itunes in an evening, with a minimum of buffering required. But for the last week or so, I've barely been able to stream anything without hours of buffering before hand. I've been with Plusnet for 10+ years  without any problems. Any Ideas?
D.M.
Plusnet Staff
Plusnet Staff
Fixes: 115
Re: sudden lack of streaming capability.
Hello there. Sorry to hear that you're experiencing slow speeds. Have you been through any trouble shooting yet/Are you connecting over wireless or a wired connection? In the mean time I'll be happy to run a few tests on our side tomorrow morning for you.
I've joined the Plusnet Help Team as of May 2017. As such, I have a new forum account. Please direct any queries to @Gandalf. Thanks
 Plusnet Support
DunMcH22
Thanks for replying. I'm connecting over wireless, but don't seem to have to have any problem with normal web browsing. i've made sure that I'm using a relatively uncluttered channel for wifi. I should say that I normally switch off my router overnight. I know that I shouldn't ,but I've done it for 10+ years without impacting my broadband speed. My router is a Netgear DGN2200v4.
D.M.
Plusnet Staff
Plusnet Staff
Fixes: 115
@DunMcH22 I'm having difficulty in locating your account. Can you PM me your username please?
 Plusnet Support
Plusnet Staff
Plusnet Staff
Fixes: 115
Thanks for your PM.
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 17.8 27.5
SNR Margin: 6.2 3.0
Errored Seconds: 0 0
HEC Errors: 0
Cell Count: 662 10123
Speed: 1279 17991
Whilst your connection is stable, the signal to noise ratio is too low which can cause speed/throughput issues. I've made a change to DLM now to raise this which should come into effect within 1 hour.
 Plusnet Support
DunMcH22
Thanks for all you help. I've also purchased and set up a new Modem/Router (Netgear D7000). This seems to have given me a more stable Wifi signal/speed of about 15Mbs. I'm going to try and stream a HD movie tonight to see if everything is back to normal. And then monitor it for a few days.
Many thanks,
D.M.
Plusnet Staff
Plusnet Staff
Fixes: 115
Awesomeness, no problem. Hopefully it should resolve your issue.
 Plusnet Support
