streaming problems
- streaming problems
streaming problems
08-05-2014 10:26 PM
Re: streaming problems
08-05-2014 10:27 PM
http://usertools.plus.net/@gateway/
08-05-2014 10:29 PM
08-05-2014 10:31 PM
Ex-Broadband Service Manager
08-05-2014 10:35 PM
08-05-2014 10:36 PM
I've checked your line and can't spot anything obvious a TBB Graph would be great.
08-05-2014 10:47 PM
http://www.thinkbroadband.com/ping/share/9cef3b8b49de4967b8b35118bfbe227f.html
09-05-2014 5:43 PM
Quote from: Kelly You got a thinkbb graph? Are you seeing consistent loss? Or just a spike?
I've dropped a graph above, I wasn't quite sure if it was just a one off spike last night or not, but looking at the full hours on the sam graph today tells me it was a more sustained loss i had last evening.
[tt]Date
Failure Rate (%)
23:00 0.08
22:00 0.00
21:00 5.07
20:00 0.34
19:00 0.00
18:00 0.00
17:00 0.00[/tt]
10-05-2014 11:22 AM
10-05-2014 11:34 AM
My iPlayer traffic is being hosted by Akamai (outside the UK) and routed by Telia - 213-248-111-172.customer.teliacarrier.com
Next time it happens, my be worth looking at which CDN is being used and doing some pings.
10-05-2014 12:13 PM
Quote Next time it happens, my be worth looking at which CDN is being used and doing some pings.
I'll have a mooch at that side of things next time it happens, I thought it was down to plusnet to be looking after this sort of stuff for us! No?
10-05-2014 12:56 PM
[tt]traceroute to www.metoffice.gov.uk (212.56.73.144), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 1.357 ms
2 lo0-central10.pcl-ag07.plus.net (195.166.128.188) 48.380 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.184) 21.223 ms
4 xe-9-0-0.pcl-cr01.plus.net (212.159.0.216) 20.387 ms
5 cache.akamai.com (212.56.73.144) 20.483 ms[/tt]
(On a PTN gateway it seems www.metoffice.gov.uk still resolves to 23.62.53.115 or a similar IP.)
[tt]traceroute to cp41752.edgefcs.net (213.248.111.84), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 1.360 ms
2 lo0-central10.pcl-ag07.plus.net (195.166.128.188) 21.665 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.184) 20.808 ms
4 xe-9-0-0.pcl-cr01.plus.net (212.159.0.216) 20.073 ms
5 xe-11-1-0.edge3.London2.Level3.net (212.187.201.209) 20.653 ms
6 vl-3201-ve-128.ebr2.London2.Level3.net (4.69.202.177) 27.380 ms
7 ae-43-43.ebr1.Paris1.Level3.net (4.69.159.90) 27.345 ms
8 ae-71-71.csw2.Paris1.Level3.net (4.69.161.82) 27.711 ms
9 ae-2-70.edge3.Paris1.Level3.net (4.69.168.70) 27.990 ms
10 telia-level3.paris1.Level3.net (4.68.62.250) 28.255 ms
11 prs-bb2-link.telia.net (213.155.132.198) 29.662 ms
12 prs-b8-link.telia.net (213.155.131.11) 29.575 ms
13 213-248-111-84.customer.teliacarrier.com (213.248.111.84) 29.369 ms[/tt]
So there's still a short route for akamai web content, but a longer route for streaming.
10-05-2014 4:20 PM
[tt]
traceroute to 212.56.73.56 (212.56.73.56), 30 hops max, 60 byte packets
1 192.168.0.254 (192.168.0.254) 35.431 ms 35.295 ms 35.203 ms
2 lo0-central10.pcl-ag05.plus.net (195.166.128.186) 22.426 ms 22.403 ms 22.381 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.176) 21.227 ms 22.298 ms 22.290 ms
4 xe-1-2-0.pcl-cr01.plus.net (212.159.0.208) 24.178 ms 24.601 ms 24.600 ms
5 cache.akamai.com (212.56.73.56) 22.188 ms 22.487 ms 22.447 ms
traceroute to 213.248.111.164 (213.248.111.164), 30 hops max, 60 byte packets
1 192.168.0.254 (192.168.0.254) 97.520 ms 97.353 ms 97.205 ms
2 lo0-central10.pcl-ag05.plus.net (195.166.128.186) 22.268 ms 22.283 ms 22.231 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.176) 20.398 ms 20.545 ms 22.066 ms
4 xe-1-2-0.pcl-cr01.plus.net (212.159.0.208) 25.796 ms 25.725 ms 25.707 ms
5 xe-11-1-0.edge3.London2.Level3.net (212.187.201.209) 21.800 ms 24.100 ms xe-11-2-0.edge3.London2.Level3.net (212.187.201.213) 21.785 ms
6 vl-3201-ve-128.ebr2.London2.Level3.net (4.69.202.177) 28.164 ms 23.599 ms 25.179 ms
7 ae-42-42.ebr1.Paris1.Level3.net (4.69.159.86) 25.730 ms ae-43-43.ebr1.Paris1.Level3.net (4.69.159.90) 25.317 ms ae-44-44.ebr1.Paris1.Level3.net (4.69.159.94) 27.267 ms
8 ae-91-91.csw4.Paris1.Level3.net (4.69.161.90) 27.251 ms ae-71-71.csw2.Paris1.Level3.net (4.69.161.82) 27.233 ms ae-91-91.csw4.Paris1.Level3.net (4.69.161.90) 27.209 ms
9 ae-3-80.edge3.Paris1.Level3.net (4.69.168.134) 72.251 ms ae-1-60.edge3.Paris1.Level3.net (4.69.168.6) 24.832 ms 24.804 ms
10 telia-level3-ge.paris1.Level3.net (4.68.62.126) 26.660 ms 25.376 ms 25.308 ms
11 prs-bb2-link.telia.net (213.155.134.230) 24.983 ms prs-bb1-link.telia.net (213.155.134.224) 25.352 ms prs-bb1-link.telia.net (213.155.132.192) 32.855 ms
12 prs-b8-link.telia.net (213.155.136.207) 26.371 ms prs-b8-link.telia.net (213.155.131.19) 25.849 ms prs-b8-link.telia.net (213.155.131.1) 26.633 ms
13 213-248-111-164.customer.teliacarrier.com (213.248.111.164) 27.326 ms * *
traceroute to 95.140.227.188 (95.140.227.188), 30 hops max, 60 byte packets
1 192.168.0.254 (192.168.0.254) 33.918 ms 33.773 ms 33.660 ms
2 lo0-central10.pcl-ag05.plus.net (195.166.128.186) 103.642 ms 103.932 ms 104.807 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.176) 20.960 ms 21.606 ms 21.595 ms
4 xe-1-2-0.pcl-cr01.plus.net (212.159.0.208) 21.569 ms 21.531 ms 22.437 ms
5 ae1.ptw-cr01.plus.net (195.166.129.0) 22.443 ms 22.413 ms ae2.pcl-cr02.plus.net (195.166.129.7) 22.382 ms
6 tge8-5.fr3.lon.llnw.net (178.79.206.2) 30.384 ms 17.462 ms 18.849 ms
7 * * *
8 ve8.fr4.lcy1.llnw.net (87.248.196.17) 19.021 ms fcds188.lcy.llnw.net (95.140.227.188) 19.223 ms 20.152 ms[/tt]
10-05-2014 5:05 PM
The only thing I came up with (apart from the PN graphs) were the free peering exchanges - http://www.lonap.net/mrtg/lonap-total.html and https://www.linx.net/pubtools/trafficstats.html?stats=day
I'm not sure how representative they are of ISP end user traffic, but I suppose they must be a bit of a guide.
11-05-2014 12:35 PM
