strange key
- Re: strange key
strange key
08-01-2016 3:30 PM
HI, hope I'm in the right area!
If I go to Network > internet > manage wireless networks, (win 7), under security tab the key is shown as :7C1EBFA16A8A43D9EB053050658D48F5CE4779EA09DED6C01B333643FC7F05FD, and not the key shown on the router, is this OK?
Best regards and a happy new year
Message 1 of 4
(1,212 Views)
3 REPLIES 3
Re: strange key
09-01-2016 10:11 AM
Whilst I do not know the detail around this, if it's working do not worry! I would not expect any security key to be sorted anywhere in 'plain' text. I suggest that what you have found in the registry (a dangerous place to mess around in) is a hashed version of your wifi security key.
Message 2 of 4
(576 Views)
Re: strange key
09-01-2016 3:28 PM
Probably not made myself clear!
This is not the registry this is CONTROL PANEL > NETWORK AND INTERNET > MANAGE WIRELESS NETWORKS > SECURITY.
Sorry if I have not explained properly.
Message 3 of 4
(576 Views)
Re: strange key
09-01-2016 3:44 PM
WPA2-PSK wireless security uses a 64 byte hex key like the one you have given. (PS I suggest you remove it)
Most of the time you will use a Passphrase when configuring your router or clients, as it's easer than typing a 64 byte key.
This is converted with the SSID into the 64 byte hex key. This website will convert an ESSID and Passphrase onto the 64 byte key.
Message 4 of 4
(576 Views)
