static IP
- Re: static IP
static IP
22-05-2014 2:50 PM
how do i get a static IP address?
i can see the fee is a one-off £5, but can't see any way of actually requesting one.
Message 1 of 8
(1,671 Views)
7 REPLIES 7
Re: static IP
22-05-2014 2:57 PM
You can do this via https://portal.plus.net/AddOns.html
You will require a reboot of your router once this is active.
Message 2 of 8
(711 Views)
Re: static IP
22-05-2014 6:53 PM
@Chris would this help with gaming ? what are the advantages of a static IP
Message 3 of 8
(711 Views)
Re: static IP
22-05-2014 7:11 PM
A static IP for gaming isn't much help unless you host a server on your lan to make it easier for players to find it by manually entering the IP address, but no one does that anymore as its frowned on as its 0 ping hosting. So you have the big advantage unless the game uses that annoying fake ping crap.
The real benefit comes when having remote access to servers / vpn etc, then the techs on the remote host set your static IP address as allowed to access them remotely. I got one when I was a IRC admin and for two game servers I ran remotely.
FTTP 500 regrade from Tues 28th November
Message 4 of 8
(711 Views)
Re: static IP
23-05-2014 12:06 PM
Cheers for the info Gus
Message 5 of 8
(711 Views)
Re: static IP
23-05-2014 12:19 PM
Quote from: Chris You can do this via https://portal.plus.net/AddOns.html
have added the static IP to my account.
shame i'll need to reboot my router though... it has managed to stay connected for a couple of weeks now, which compared to previously is a miracle.
i hope the reboot doesn't affect the stable-ness.
does it have to be a full reboot, or can i just drop the PPP connection?
Message 6 of 8
(711 Views)
Re: static IP
23-05-2014 12:27 PM
Just drop the PPP connection as this should do it
Message 7 of 8
(711 Views)
Re: static IP
23-05-2014 1:04 PM
As Oldjim has said above you don't need to actually reboot the router just dropping and re connecting the PPP session works fine. Although personally on FTTC I find rebooting the router(leaving OR Modem alone) occasionally from within the routers web interface increases my whole network performance.
Message 8 of 8
(711 Views)
