stable at 4.5 but fixed at 3.5
- Re: stable at 4.5 but fixed at 3.5
05-02-2011 9:24 AM
Stats below. According to the portal my speed is set at 3500 kbps. Is that what I should expect given the actual connection speed is nearly 30% higher?
System Up Time 15 days 01:48:25
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 3691101 5886988 0 355 2296 14 days 07:46:11
LAN 100M/Full 0 0 0 0 0 15 days 01:48:05
WLAN 11M/54M 6472344 4176968 0 2597 410 15 days 01:48:25
ADSL Link Downstream Upstream
Connection Speed 4512 kbps 448 kbps
Line Attenuation 40.5 db 23.0 db
Noise Margin 10.0 db 23 db
Message 1 of 3
(629 Views)
2 REPLIES 2
05-02-2011 9:51 AM
Message 2 of 3
(308 Views)
07-02-2011 2:08 PM
HI the groundsman,
At the moment the sync rate you have will only get that profile. I do reckon we could get a little more out of your line though. Are you using an extension socket/cable at all? Can you plug into the test socket for me so I can run some more checks?
Jojo
Jojo
Message 3 of 3
(308 Views)
