speed
BLINDPEW
speed
My sync speed is 7616 my broadband speed shows has 6500 on my connections page but I can only get a max speed of 3500. Any help or advice would be welcome to increasing the speed.
ed
Re: speed
My tips...
don't connect to an extension lead connect to the master socket
adsl filter in front of every phone
don't let the modem cable trail over your power cable
never ever line share, if there are not enough telegraph poles in your street ask BT to put a new one in (prefebly not infornt of your house Tongue)
Luzern
All Star
Re: speed
Quote from: ed
My tips...
What would you say is the maximun cable run you should have from modem or router to the master socket to benefit from the direct connection? Do you mean the test socket?
ed
Re: speed
The shorter the better. I doubt it's shielded from electronic interference so the longer it is the more line noise you're going to be adding.
fceluk
Re: speed
If possible it's usually better on long runs to position the modem/router near the master socket and run the distance to the PC with an ethernet cable as ethernet can stand much longer runs without seriously degrading the signal.
Dick
Luzern
All Star
Re: speed
Quote from: fceluk
... ethernet can stand much longer runs without seriously degrading the signal.
Dick
Although Ethernet is not subject to degrading to the extent of phone cable, is there a limit after which you would not go?
MikeWhitehead
Re: speed
Ethernet should not be run longer than 100m, although the shorter the better (for obvious reasons). 100m is the maximum length defined in the specification.
Fixes: 103
Re: speed
Quote from: BLINDPEW
What does a speedtest here tell you? It's the IP Profile that I'm interested in.
Check to see if the VPs at your exchange are contended.
It's also worth you reviewing your MTU/RWIN settings.
BLINDPEW
Re: speed
Here are my stats from the BT speed testerTest1 comprises of Best Effort Test:  -provides background information.
    IP profile for your line is - 6500 kbps
    DSL connection rate: 448 kbps(UP-STREAM)  7616 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 3618 kbps
May I also add that my router is connected into the master socket via a filter and is approx 1 foot away from the master socket. I also get the same speedtest results plugged into the test socket.
Fixes: 103
Re: speed
That looks pretty normal.
What about your exchange congestion and MTU/RWIN settings?
BLINDPEW
Re: speed
I have run Dr tcp and my settings are ok. But I am on vista and so I think that your best off leaving your settings alone and letting the O.S sort it. But I have also got a laptop running on XP and I'm getting same speeds (3600) and mtu settings OK on that too.
Fixes: 103
Re: speed
Exchange congestion?
Also, how is it you're establishing your download speed? Using an online speedtester?
BLINDPEW
Re: speed
Date Download Speed Upload Speed
Today 20:04 3792 kbps (474 KB/s) 325 kbps (40.6 KB/s)
Not sure I know what you mean about exchange congestion but when I go on the link you gave me everything shows has green and ok
Fixes: 71
Re: speed
Both download and upload speed are less than I would expect them to be.  Normally upload speed doesn't vary much and I would expect your value to be about 380kbps measured using the mybroadbandspeed tester.
What model of modem/router do you use and how do your PC and laptop connect to it?  What are your line stats (sync speeds, noise margins and attenuations - downstream and upstream)?
My feeling is that diagnosing speed related problems on the XP laptop is less of a black art than on Vista.  Is the router MTU compatible with the MTU on the laptop?
Could you run a tweaktest using the laptop at DSLreports and post the results URL you'll be given (in small letters near the bottom of the page)?  The graphs in the more-details section of that sometimes give clues to help understand what goes on during data transfer.
David
BLINDPEW
Re: speed
I use a speedtouch 780wl and I am connected wirelessly to both pc and laptop has my router is connected directly into the master socket so I don't have any extention wiring. I can't seem to get the tweaktester up at the moment but I'll keep trying. Here are my line stats.
Link Information
Uptime: 0 days, 12:40:54
Modulation: G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Data Transferred (Sent/Received) [MB/MB]: 2.56 / 12.26
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 24.0 / 41.0
SN Margin (Up/Down) [dB]: 23.0 / 7.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1,447 / 0
FEC Errors (Up/Down): 18 / 147,990
CRC Errors (Up/Down): 4 / 199
HEC Errors (Up/Down): 2 / 186
