speed test
redbull2k14
speed test
Anyone know why on a multi threaded download I always get a low result.
edit: forgot to mention this is a wired connection.
simonhiggs
Re: speed test
The only browser that seems to work here (on a mac) is Chrome.
Simon.
Fixes: 62
Re: speed test
redbull2k14
Re: speed test
jim it is not just that speed test site, speedtest@btwholesale is exactly the same but reports 21.09.  I have an issue with multi threaded downloads. My fault has been on going for over a month now ive had 3 engineers all say no problems so there is something plusnets side and im wondering if anyone knows what.
Fixes: 62
Re: speed test
For clarity
Which router do you have
Which operating system
Which internet security package
redbull2k14
Re: speed test
I have windows 8.1
I do not use any security package.
the problem has been on going with 3 routers. 2 of which were tg582n and dsl n66u
Fixes: 62
Re: speed test
the one thing I forgot to ask - have you tried with different browsers
redbull2k14
Re: speed test
thanks jim, problem solved. Now time to find the problem in firefox, any suggestions?
Fixes: 62
Re: speed test
If you start Firefox in safe mode and then try a test which isn't flash based is that any difference
redbull2k14
Re: speed test
thanks again jim, found the add on, 'Addblock Plus' will report to them.
Re: speed test
Not sure that ABP is responsible, at least for me...
IE11
FF30 ABP off
FF30 ABP on
This last one was also taken by Firefox, first one when I had the FTTC installed. Things have gone downhill a tad, but the TBB download has generally always been better than HTTPx6 for me.
I need to check a few things locally, but I suspect I may be raising a speed fault next week...  Sad
