speed test
- Re: speed test
speed test
12-02-2013 12:26 PM
When I do a plusnet speed test I always get the notification:
Sorry - My Broadband Speed is currently experiencing technical difficulty and may display misleading test results. Thanks for bearing with us while we fix things
Any one else get this? How can I get a true result?
Message 1 of 3
(587 Views)
2 REPLIES 2
Re: speed test
12-02-2013 1:12 PM
It's been like this for quite some time and I'm not sure if a fix is on the cards.
Results provided can be ok, it depends on circumstances like the load on the system.
People generally use http://www.speedtest.net/
Message 2 of 3
(319 Views)
Re: speed test
12-02-2013 4:08 PM
Thanks for the info. Will use the link suggested.
Message 3 of 3
(319 Views)
