speed slow following exchange problem
ketter
Hi
Yesterday you fixed a problem in our local exchange that was stopping us having broadband, thanks goodness. back online after a week.
But, I'm suffereing serious speed loss since this issue was fixed and being back online.
I've run a test and this is the results:
and snapshot of my router stats is attached
can you help with this please?
Fixes: 247
Re: speed slow following exchange problem
if you run further diagnostics on the bt speedtest (http://speedtest.btwholesale.com/) what profile do you get?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
ketter
Hi Dvorak
After having followed their instructions, sadly I don't seem to get any profile (?)
Download Speed (Mbps): 1.92
Upload Speed (Mbps): 0.34
Ping Latency(ms): 33.13
FAQ
1. Best Effort Test:
Download Speed : 1.92 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Fixes: 68
As your connection has only just stabilised an SNR reset is needed.
I've just done that now so you should see some improvement soon.
 Adam Walker
