speed reduction?
- speed reduction?
speed reduction?
14-11-2007 7:37 PM
Hi - I have been getting speeds of around 5000 kbps for months and all of a sudden it's reduced to ~1500 kbps
is there anything that can be done to restore the faster speed? (I've rebooted my router)
thanks
Stuart
thanks
Stuart
Message 1 of 2
(1,230 Views)
1 REPLY 1
Re: speed reduction?
15-11-2007 10:02 AM
Hi Stuart,
There's a link in my signature about the wonders of upto 8Mbps broadband which might be quite helpful for you.
Basically, you've had a blip in your synchronisation speed. That's the speed of signal between your router and the exchange. When this happens, BT lower your speed profile down to a value near the low sync event. now that you're syncing at a higher level, your speeds will rise, but this can take up to 3 days.
Message 2 of 2
(222 Views)
