speed problem.
- Re: speed problem.
speed problem.
12-01-2008 5:14 PM
Message 1 of 8
(1,831 Views)
7 REPLIES 7
Re: speed problem.
12-01-2008 5:24 PM
Have you tried rebooting your router. Changing the gateway you are on may improve things.
Message 2 of 8
(513 Views)
Re: speed problem.
12-01-2008 5:32 PM
Yes.... first thing I did was power everything down, reboot and test again.
Message 3 of 8
(513 Views)
Re: speed problem.
12-01-2008 5:45 PM
I can see from checking your usage that you have just hit the 4gb limit on your account, as such this will be the cause of the slowdown. Having said that your usage will reset on Monday (when you are billed) and speeds should go back to normal then.
Hope that helps,
Hope that helps,
Message 4 of 8
(513 Views)
Re: speed problem.
12-01-2008 8:11 PM
Mostly during the daytime, including Sat & Sun.
Message 5 of 8
(513 Views)
Re: speed problem.
13-01-2008 9:35 AM
Message 6 of 8
(513 Views)
Re: speed problem.
13-01-2008 9:41 AM
Your throttling only applies during peak times, so that's 4pm to midnight. Outside of those hours it'll run much closer to line speeds. Your usage is still due to be reset tomorrow.
Hope that helps,
Hope that helps,
Message 7 of 8
(513 Views)
Re: speed problem.
13-01-2008 10:17 AM
Thanks for the info.
I've been using a couple of Internet radios during the last month or so, I expect that will have bumped up my usage. The stations I mainly listen to stream at 128 kbps.
Message 8 of 8
(513 Views)
