speed /noise fault fixed by BT, can I have my iP profile raised please?
- speed /noise fault fixed by BT, can I have my iP ...
06-05-2010 5:26 PM
BT guy has been round this afternoon and fixed the noise on my line, he tells me the BRAS is now set to 4500, so please could someone increase the PN IP profile to match?
Ticket no: 33059335 if that helps
Ta
Re: speed /noise fault fixed by BT, can I have my iP profile raised please?
06-05-2010 5:31 PM
06-05-2010 5:49 PM
If you look at this routerstats graph you'll see I was synced at 4800 earlier, with snr of 6, then the engineer did something at the exchange which dropped the sync to 3872 and snr went up to 8. It was this sync of 4800 that the guy said was the reason they set the BRAS at 4500.
I was planning on doing a reboot of the router about 9.30 am tomorrow to get the best possible sync then leaving well alone.
The BRAS was certainly 1500 last time I ran the BT speed test but that was before he fixed the problem. He told me over the phone at 5pm that the BRAS was 4500 now- was this a little white lie?
06-05-2010 6:25 PM
Quote FAQ
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
707 Kbps
0 Kbps 2000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 707 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :3872 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1500 Kbps
looks like it was an untruth regarding 4500, oh well, will wait for it to increase
07-05-2010 9:35 AM
Why?
Can someone please at least increase it to the same as BT.
Seems pointless the fella coming yesterday and sorting out my line if PN are still going to throttle it.
EDIT: now synced at 4160 by the way
07-05-2010 2:07 PM
I started syncing at 3800 but by the time the DLM had finished I was at 2200..
07-05-2010 10:54 PM
10-05-2010 8:15 AM
Quote Test1 comprises of Best Effort Test: -provides background information.
Download Speed
1319 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 1319 Kbps
Your DSL Connection Rate :5088 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 4000 Kbps
still getting this:
Quote Phone exchange:
RANMOOR
Estimated line speed:
0.5 - Checked on 2010-04-19 22:27:56
Current line speed:
1500
Could someone switch me on please?
10-05-2010 9:25 AM
10-05-2010 11:01 AM
Line appears to be nice and stable. Hopefully won't have any more problems.
Incidentally I was part way through an SNR retrain period when the engineer came last week- there had been a period of a few days when it was stable at a decent sync but the SNR was 17. My SNR is now 8.5, attenuation 42.5 (was 36 before the engineer fixed the line- he "swapped a pair" I think)
Would it be worth doing another SNR re-train now, as I have essentially got a new line with new characteristics, or are these stats as good as I'm going to see?
Was thinking I might get a little more speed to get me into the 4500 BRAS profile if the SNR could be held at 6?
Worth a shot or leave alone?
10-05-2010 11:11 AM
10-05-2010 2:41 PM
