speed issues!
- speed issues!
Re: speed issues!
04-09-2007 3:32 PM
For me (7648sync, 6500kbps profile) mybroadbandspeed (MBBS) gives 6145kbps download but thinkbroadband (TBB) 5975kbps. The former test is much shorter than the latter so, in principle the latter should be more robust. However the data-rate shown by DU Meter is identical in each case. The difference may be that TBB reports an average speed whereas MBBS gives a peak value - I'm not sure whether this is the case.
Re: speed issues!
04-09-2007 3:36 PM
I believe it got set back because of our 90 day project following on from the webmail incident.
Re: speed issues!
04-09-2007 4:12 PM
Quote from: spraxyt
Also the graph needs extending. After the excellent work you did in getting my speed up spraxyt, it's not possible to read the values when you hover over them.
The graph finishes at 5500kbps.
Boy, you're getting some good speeds. Do you live in the telephone exchange
Re: speed issues!
04-09-2007 5:11 PM
Quote from: artmo Also the graph needs extending. After the excellent work you did in getting my speed up spraxyt, it's not possible to read the values when you hover over them. The graph finishes at 5500kbps.
Sorry, I don't follow this - what graph are you referring to?
Quote Boy, you're getting some good speeds. Do you live in the telephone exchange
Samknows reckons I'm 926m from the exchange straight-line, which seems about right. I guess this means 1300m line length assuming the line follows the roads - 0.8 miles in a more meaningful unit. Attenuation is 33dB. I can sync at 8128kbps during the day but smaller SNR margins at night result in sync reducing to what I have now. I leave it at that to avoid ups and downs.
I'm currently test-driving a BT Voyager 210 router like you have but connected using Ethernet rather than USB. USB is known to give slower speeds, though I don't have a feel for the typical impact (or whether tuning can reduce the impact).
I worked through the RWIN/MTU saga as you have to get my speeds up, though doing it using hints in other posts under my own steam, so to speak, since I have the background knowledge.
I purposely haven't previously quoted my speeds to you, since I didn't want you to be disappointed at "only" 5000kbps (from 3000kbps start). I'm conscious that you seem to have been doing an abundance of speed and tweak tests at my behest, might be wondering when it would end. Now I have the 210 I intend to try it using the USB connection so that I can get a feel for any impact on speeds.
Re: speed issues!
04-09-2007 5:40 PM
Quote from: spraxyt
On the Mybroadband Speed tester there's a facility to view your results in graph form.
I'm not complaining at what you got for me on speed. For the type of use I have that's great.
I'm about the same distance (930m) as you from my exchange according to dslzoneUK. I'd be interested in your findings once you've done your test drive.
Re: speed issues!
04-09-2007 8:26 PM
As you said data-points aren't displayed when one hovers over them, but the values are tabulated further down the page. It's a simple graph, but in my view quite suitable to show any trends.
Re: speed issues!
06-09-2007 11:24 AM
Quote from: James I'll try and find out what the latest is on this.
It's sat on nice shiny hardware in Sheffield and just needs moving to London and plumbing it. Been waiting for that move since Februrary. I'll chase personally today as I'm a bit fed up of waiting!
Ex-Broadband Service Manager
Re: speed issues!
06-09-2007 11:47 AM
Quote from: Kelly
As a matter of interest why does it have to move to London?
Re: speed issues!
06-09-2007 3:28 PM
Quote from: artmo …I'd be interested in your findings once you've done your test drive.
I've posted comprehensive details of ad-hoc speedtests using the Voyager 210 router in the PlusNet Usergroup forums ("Results from ad-hoc speedtests comparing Ethernet and USB connections"). The summary paragraphs most relevant to your USB set-up are as follows:
"Comparing USB and Ethernet connections shows USB is around 600-650kbps slower than Ethernet with MTU=1400 but the difference reduces to 300-350kbps with MTU=1500.
Comparing MTU=1400 and MTU=1500 shows little variation for the Ethernet connection but using USB the larger MTU improves throughput by around 300kbps".
Would you like to try MTU=1500 to see what you get?
(I assume guidance on making the changes might be needed; I'll be out now until late evening.)
Re: speed issues!
06-09-2007 4:07 PM
Quote from: artmo As a matter of interest why does it have to move to London?
The connection between the customer and the internet is in London. To host the servers in Sheffield means adding that extra loop in whcih, in busy times, could conceivably effect the quality of the result, and possibly the performance of the network!
Re: speed issues!
06-09-2007 5:30 PM
Thanks Kelly.
Re: speed issues!
06-09-2007 5:33 PM
Quote from: spraxyt
Thanks for the information. Yes, I would like to see what I can get by increasing MTU to 1500. Can I put it on hold for a while. I leave for the US early Tuesday and running a bit tight on time. I'll be in touch when I return if that's OK. I'm due back around 14th October.
Re: speed issues!
06-09-2007 11:07 PM
Quote from: artmo …I would like to see what I can get by increasing MTU to 1500. Can I put it on hold for a while. I leave for the US early Tuesday and running a bit tight on time.
That's fine, best not to rush things when timescales are tight.
Enjoy your holiday!
Re: speed issues!
07-09-2007 10:34 AM
my 8meg (6900) line drops to around a mere 2000. i notify force9 who say nothings wrong, then next day all is back to normal.
It has started this again yesterday. today i am registering a mere 436 line,, i think since these speeds are during 'peek' hours i am being throttled by someone!! yet i have never reached near any limits, not been told or even warned i may be .. i think i am not happy
Re: speed issues!
07-09-2007 10:38 AM
There's no throttling going on at this end.
Do you know what speed your router is gaining synchronisation with the exchange at? I'm afraid that I'm not able to see this information without your raising a fault with us.
