speed issue
- Re: speed issue
speed issue
12-10-2011 6:59 AM
over the last couple of days i have had noise on my line, which turned ot to be a faulty phone.
when i checked my broadband speed yesterday i was only geting 3014 Kbps according to the BT speedtester, normally i get full speed for my connection rate "Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)" Saturday 00:32 6736 kbps (842kB/s) 381 kbps (47.6kB/s)
but it is showing my IP Profile for my line is - 3500 Kbps, where up to the line issue was 7150, how can i get back to this asap?
cheers
cheers
Message 1 of 9
(1,292 Views)
8 REPLIES 8
Re: speed issue
12-10-2011 4:51 PM
Hi cyclopops,
your line just needs to stay stable. Don't be tempted to reboot, and if it's still the same in the morning, give me a shout and I'll see if there's anything I can do.
Jojo
Jojo
Message 2 of 9
(690 Views)
Re: speed issue
13-10-2011 6:09 AM
back to normal, dont know if you did anything jojo, but thanks anyway
Today 06:07 6727 kbps (841kB/s)
Message 3 of 9
(690 Views)
Re: speed issue
13-10-2011 8:33 AM
No, didn't do anything, just needed to wait for the profile to lift.
Message 4 of 9
(690 Views)
Re: speed issue
18-10-2011 7:17 AM
well 7 days later, and its done it again, my IP Profile for your line is - 3000 Kbps, and my speed has dropped to 2920 kbps (365kB/s), so basically twice in about a week, i do hope this is not going to be normal service, i have come from a service that was very reliable (never skipped a beat in the 3 years i was there).
i have rebooted my router this morning, and right away i am back to DSL Connection Rate :8128 Kbps, i know you will say not to do that, but its the only way of quickly getting my router to get to that connection speed (last time i left it a few days and it stayed at 3500 profile)
as a little bit of extra info, my phone line was due to switch over from BT to plusnet yesterday, could this have caused this issue?
i also noted last night the my SNR was 22, when normally it is around 6
Message 5 of 9
(690 Views)
Re: speed issue
19-10-2011 10:47 AM
Not sure whether that could have caused it. Are you using any extension cables/sockets for your router connection?
Message 6 of 9
(690 Views)
Re: speed issue
19-10-2011 12:00 PM
no, my router goes straight into the face plate, (filter inbuilt)
Message 7 of 9
(690 Views)
Re: speed issue
19-10-2011 11:05 PM
Well just keep an eye on it and let us know if it goes funny again
Message 8 of 9
(690 Views)
Re: speed issue
20-10-2011 6:24 AM
will do
thanks
thanks
Message 9 of 9
(690 Views)
