speed issue..........
jld51
line profile has dropped from 70+ to 24 speed gone from 72 Mbps to  >:(11.51.
1. Best Effort Test:  -provides background information.
Download Speed
11.51 Mbps
0 Mbps 24.57 Mbps
Max Achievable Speed
Download speedachieved during the test was - 11.51 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-24.57 Mbps .
Additional Information:
IP Profile for your line is - 24.57 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
12.6 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 12.6Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
10 REPLIES 10
Pettitto
Fixes: 5
Re: speed issue..........
Hi jld51,
I'm really sorry to hear of the issues you're having here. If you could raise a fault with us at http://faults.plus.net we'll ensure we get that sorted out for you.
jld51
Thank you for a fast response. ticket has been raised.
Pettitto
Fixes: 5
No problem.
Can you ensure that the Fault Checker is completed all the way through?
jld51
Did the fault checker need to take 3 speed tests do i then post them  here.or to the open ticket.
jim:quote
Pettitto
Fixes: 5
If you've completed a Speed Test at http://speedtest.btwholesale.com including 'Further Diagnostics' then you can progress the Fault Checker to the end.
jld51
all i keep getting is
FAQ
null
You appear to have not logged on as speedtest@speedtest_domain. In order to run the next test you should login as speedtest@speedtest_domain.
Please wait while you are redirected..
never get redirected
dick:quote
Pettitto
Fixes: 5
On the Broadband Fault Checker, just keep clicking 'Next' until it's completed, I'm pretty certain that the information we've got from your initial Speed Test will be enough.
jld51
I assume nothing will be done over the easter break.......
jld51
Engineer phones at 7-50 am this morning asks if he can call around,result job done quick service  Smiley Smiley Smiley
Pettitto
Fixes: 5
Great stuff Smiley
Our Support Team and Openreach still work through the Easter Break - I'm glad everything has been sorted out for you Smiley
