speed increase
- speed increase
speed increase
11-06-2011 10:50 AM
hi there, i have some hd content ive edited for youtube, and even with the small res file its not going to be fast.
any change i can get my upload uncapped if so, how much and what speed.
Message 1 of 5
(8,626 Views)
4 REPLIES 4
Re: speed increase
11-06-2011 1:43 PM
If you are on maxADSL you can opt for Max Premium which gives upload speeds up to 832kbps and costs £7.83 per month. Details here.
If you are on ADSL2+ you can ask for your upload speed to be uncapped which gives upload speeds up to 1Mbps and is free. Just raise a ticket to request it.
David
Message 2 of 5
(348 Views)
Re: speed increase
11-06-2011 2:21 PM
Just adding to this, If you request it, it won't get done over the weekend as we need to place an order to BT and they don't class weekend as working days.
Message 3 of 5
(348 Views)
Re: speed increase
11-06-2011 3:29 PM
ok, so is there some line or test that i press a tab and sees if im able to do it?
Message 4 of 5
(348 Views)
Re: speed increase
11-06-2011 3:31 PM
Look on the exchange checker and see if your exchange is 21CN enabled http://usertools.plus.net/exchanges/
Message 5 of 5
(348 Views)
