speed drop
- Re: speed drop
- « Previous
- Next »
Re: speed drop
22-07-2015 3:03 AM
Re: speed drop
22-07-2015 9:36 AM
New firmware - are you talking about 10.2.2.B for the TG582n? If yes, it is a very good move, I would urge to to request it.
At the moment your synch stats look good, what results do you get from the BT speedtest - further diagnostics? Ignore the instruction to reboot the router. Need speed test result an profile figure. As noted you can nolonger check the PlusNET profile figure - you will have to call support (or use chat) and ask for the figure / for it to be checked.
Re: speed drop
22-07-2015 9:36 AM
Re: speed drop
22-07-2015 12:21 PM
this is the result from plusnet's link.
Estimated line speed:
7Mb (This may vary between 6Mb and 8Mb) - Checked on 2015-05-06 14:17:21
Current line speed:
2.9 Mb
as for the info in #23, i can't see how to get that from this router. it offers me statistics and connection status.
Re: speed drop
22-07-2015 12:51 PM
I see that the PlusNET profile which "does not very often fail to change correctly any more" (justification for removing the link in the user portal) is not right for the current line speed. If you only got the improved synch speed this morning, then that might be reasonable, if earlier then something is still amiss in the process.
@CRT, can you please confirm that the PN profile is correct and feed back to the "decision maker" how useful direct access to the current speed is in enabling users to assist themselves? I do hope that this change will be recinded.
Re: speed drop
22-07-2015 1:36 PM
Chapter 4: Managing Your Network
N300 Wireless Gigabit ADSL2+ Mode
m Router DGN3500 User Manual
Statistics
To view statistics, on the Router Status screen, click Show Statistics
Figure 31.
The following table describes the wire
less modem router statistics.
To change the polling frequency, enter a time in seconds in the
Poll Interval field, and click Set Interval
T o stop the polling, click Stop
ItemDescription
System Up Time The time elapsed since the wireless modem router was last restarted.
Port The statistics for the WAN (Internet) and
LAN (Ethernet) ports. For each port, the
screen displays:
Status The link status of the port.
TxPkts The number of packets transmitted on this port since reset or manual clear.
RxPkts The number of packets received on this port since reset or manual clear.
Collisions The number of collisions on this port since reset or manual clear.
Tx B/s The current transmission (outbound)
bandwidth used on the WAN and LAN ports.
Rx B/s The current reception (inbound) ban
Up Time The time elapsed since this port acquired the link.
Poll Interval The intervals at which the statistics are updated in this screen.
Refresh
Re: speed drop
22-07-2015 2:29 PM
Re: speed drop
22-07-2015 2:57 PM
Re: speed drop
22-07-2015 3:15 PM
Quote from: Matthew I've updated the profile now and dropped the connection.
From what I can see your in sync at around 20mbps.
Hi Matthew,
Access to current speed info is really helpful to users, would you not agree? In which case can we have the user portal link reinstated please?
Kevin
Re: speed drop
22-07-2015 4:08 PM
- « Previous
- Next »
