speed drop/noise margin rise again
monkey001
Got my 6 monthly problem again was getting around 2mb with about mid 20ms on ping and a noise margin of around 7.8 to 8.0.
Now my download is dropping ,noise margin is around 9.0 and ping all over the shop.
I won't use the fault finder as it messes with interleaving being off.
Internet is mainly used for gaming so i instantly see problems with it and is has been dropping out on my pc.I've done some speed test and some of them with rise to 1.5mb then drop to 0.5mb and it will struggle to get back up .
Having to constantly reboot my router to get a better speed and it has been changed so i know it isn't that i lefted it on for awhile too for it to only get worse.
Router is in the master socket in the test socket constantly pc/consoles are hard wired.
Any ideas or help please and yes i live along way from my exchange.
woodsider
Re: speed drop/noise margin rise again
Re:  "... constantly reboot my router to get a better speed ..."
My experience is exactly the opposite. After reading
http://community.plus.net/blog/2007/07/02/broadband-speed-faults-how-to-diagnose/
I understand why. It's worth bothering. Honest!
monkey001
Yeah have done for awhile it stayed at 2mb then just turned to [Censored] so rebooted a few time lefted it a few days and it still didn't pick up.
just seems as if every 4-6 months i have to complain then it's sorted again for a few months.
dick:quote
monkey001
monkey001
just tested BTspeedtester @ 11pm my connection rate is normally around 2.5mb with speed of around 2mb
monkey001
HuhHuhHuhHuhHuhHuhHuh?Huh
jojopillo
HI monkey001
I've just lifted our profile a bit and this will give your connection a kick, I'd be interesteed to see what you get in the next 10-15 mins.
Jojo Smiley
monkey001
Thank you jojo.
Seems better although not as good as i was getting.
Wish i kept record of what it was when it was good will monitor it for awhile.
monkey001
also while i'm here is there a cap on upload with PN?
monkey001
Bump
Yet again having problems the last month inconsistent speed :/
for some reason my speed test never registered but they never got above 1.1mb since the 3rd.
router stats was after a restart and was much worse.
ping test are saying it's well over 150m/s norm is 25m/s
jojopillo
Hi monkey001,
I don't see any obvious issues with your line, account or exchange at the moment. As you're on 20CN the upload is capped at 448k.
Jojo Smiley
monkey001
Yeah download seems to have stabilized again but at a lower speed it still won't move up to the 1.8-2mb i was getting 2 months ago.
Out of interest as i've just seen the uncapping of upload speed is there a way of seeing what your upload speed would be if it was uncapped as i have a interest in this?or does it have 1 months trial?
Thanks Jojo
jojopillo
Hi monkey001,
uncapping the upstream on your line would probably compromise the downstream which in your case isn't that high. With attenuation of 60 and noise margin of 10dB your 2208 sync is probably about right.
Jojo Smiley
monkey001
When i do a speedtest it bounces from 1.3mb to under 0.3mb there is no stability on the line which isn't good as I'm paying for it on the PRO package.
one minute pages load fine next they freeze and i have to refresh,online gaming is impossible.
will try and turn the router off in the morning see if can give me a better sync speed and my noise margin is normally around 8dB can't understand why it's got worse again.
Would interleaving being turned back on improve my connection.
jojopillo
HI monkey001,
interleaving may settle it down but can cause higher pings, which as a gamer may affect you. If you are having issues you should definitely go to http://faults.plus.net and raise a fault there.
Jojo Smiley
