speed down from 76 Mbpss to 38 Mbps once again
jld51
Been like this for the last 2 weeks.
1. Best Effort Test:  -provides background information.
Download Speed
38.8 Mbps
0 Mbps 77.44 Mbps
Max Achievable Speed
Download speedachieved during the test was - 38.8 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
13.89 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 13.89Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
Fixes: 9
Re: speed down from 76 Mbpss to 38 Mbps once again
What does https://portal.plus.net/my.html?action=data_transfer_speed say for your current line speed?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jld51
Phone exchange:
NUNEATON
Estimated line speed:
72Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-04-02 00:18:45
Current line speed:
77.4 Mb
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi jld51,
We've identified a congestion issue. Would you be able to raise a fault with us at http://faults.plus.net so that we can provide you with regular updates on this?
Chris Pettitt
Cloud Environments Engineer
jld51
Thank you I have raised a ticket and reported the fault.
