so how can you see 'sync speeds' on fibre
vetterlein
Now I have FTTC , I have two 'boxes' in t he house:
DSL---> BT Modem  --> CAT6-> Techicolor 582
The Techicolor has a web interface (and a telnet interface) that would normally  tell me lots of good things about the DSL ... but of course it can't
because the line does not even get to the box.
The only place which would know the DSL characteristics would be the BT modem ... can I get stats off this somehow?
10 REPLIES 10
Oldjim
Resting Legend
Fixes: 63
Re: so how can you see 'sync speeds' on fibre
Nope
The only way is indirectly via the BT speedtest where the IP profile is about 96.7% of the sync speed
w23
Fixes: 4
Or by 'hacking' the moden (if it's a Huawei HG612).
Call me 'w23'
Fixes: 1,483
Which of course would no doubt void any warranty and probably against the T's & C's
Anotherone
Champion
Fixes: 21
Do a forum search, there is at least one thread where I've seen Modem stats!
w23
Fixes: 4
Quote from: dvorak
Of course it's not allowed, just technically 'do-able'  Smiley
Call me 'w23'
sjrinfroyle
I stil do not understand why BT lock these modems down! I had an Openreach engineer round the other day and even he didn't understand!
Bald_Eagle1
Quote from: Gigabit
Maybe so that we can't mess with them & blame BT when our messing ruins our connections.
Or..........
[cynic]
So that we can't see exactly how bad our connections really are & to stop us having the proof with which to complain?
[/cynic]
Anotherone
Champion
Fixes: 21
Have I understood this right - Telnet into the Modem, type sh and at the # prompt then enter xdslcmd info --pbParams
Edit: Also where does http://192.168.1.78/html/content.asp ; fit in with all this?
Bald_Eagle1
Quote from: Anotherone
Also where does http://192.168.1.78/html/content.asp  fit in with all this?
Telnet Login is admin
password is admin
sh starts Busybox
Welcome Visiting Huawei  Home Gateway
Copyright by Huawei Technologies Co., Ltd.
Login:admin
Password:
ATP>sh
BusyBox v1.9.1 (2010-10-15 17:59:06 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 4829 Kbps, Downstream rate = 32264 Kbps
Path:   0, Upstream rate = 4815 Kbps, Downstream rate = 26981 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3959)
Medley Phase (Final) Band Plan
      VDSL Port Details       Upstream        Downstream
Attainable Net Data Rate:       4829 kbps         32264 kbps
Actual Aggregate Tx Power:        6.3 dBm          12.8 dBm
 VDSL Band Status        U0      U1      U2      U3      D1      D2      D3
 Line Attenuation(dB):  8.3     54.3     N/A     N/A    21.8    64.2    0.1
Signal Attenuation(dB):  9.3     53.7     N/A     N/A    21.8    64.2     N/A
       SNR Margin(dB):  6.0     6.1      N/A     N/A    6.5     6.6      N/A
        TX Power(dBm): -4.2     5.8      N/A     N/A    11.4    5.8      N/A
http://192.168.1.78/html/content.asp  is the modem's GUI
(actually the default 192.168.1.1 for my connection)
Another useful command is xdslcmd info --stats
That provides the usual connection stats including error counts etc.
Windows users can also fully graph their connection. See the link in the first post here:-
http://forum.kitz.co.uk/index.php/topic,10552.0.html
WWWombat
Don't forget that the modem isn't, initially, connected to your LAN by IP.
As well as loading new firmware, you need to also connect the 2nd LAN interface to your internal network.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
