snr
johnjarram
snr
would lowering my snr give me any more download speed
ADSL Link              Downstream  Upstream
Connection Speed 2400 kbps 448 kbps
Line Attenuation     56 db       15.5 db
Noise Margin               11 db         16 db
Re: snr
Probably, but why is it high - you need to determine that first and fix it?
If you do the SNRM should adjust automatically and speed increase, maybe to over 3mbps.
johnjarram
Re: snr
had a fault at the exchange a few months back when my connection was dropping constantly but all sorted now hasn't dropped connection since.i was with aol before and was getting 3-3.5 actual download speed syncing about 4.5
Re: snr
In that case tell PN the facts and suggest that you may have a "stuck profile" that needs to be reset.
johnjarram
Re: snr
cool cheers Smiley
