snr stats
cuke2u
snr stats
Hi, can anybody reassure me that these are ok?
Upstream SNR  26db, downstream SNR  9.0db
I'm getting downloads at dialup speeds when I'm on a ADSL Link Speed of 8128  kbps
Cheers,
Chris
Fixes: 127
Re: snr stats
On the surface they look OK.
Can you post the results of a BT Speedtest and http://www.mybroadbandspeed.co.uk
Will Moderate For Thanks
cuke2u
Re: snr stats
Hi and many thanks for your reply. I'm at work at the moment but I will post them up tonight when I get home..
Thanks again..
Chris
James
Re: snr stats
Hi Chris,
The SNR stats looks okay.  It's not a profiling issue as we're profiling your line @ 7150Kbps.
Could you let us know where you're downloading from?
cuke2u
Re: snr stats
Hi again
Still slower than they've been before but not as bad as last night
I was downloading from www.amd.com, tonight I've tried that site again and it was around 125KB/sec, www.filehippo.com at 279 and this one http://www.nvidia.com/page/uli_drivers.html was about the same as amd..
Cheers,
Chris
Fixes: 21
Re: snr stats
Speedtest.net is not the most reliable of speedtesters.
Quote from: adiewoo
If you could do that preferably at an off-peak time (early morning) and post the results.
You can check on expected maximum speeds here - http://www.plus.net/support/broadband/quality_broadband/speed.shtml
cuke2u
Re: snr stats
Hi, just go around to performing this today and here are the results
All seems fine at the moment but on that evening it was particualry bad at around 6-8 Kb/Sec I will continue to monitor it, in the meantime thanks for all your help...
Chris
