snr stats
- Re: snr stats
snr stats
19-05-2009 8:57 PM
Hi, can anybody reassure me that these are ok?
Upstream SNR 26db, downstream SNR 9.0db
I'm getting downloads at dialup speeds when I'm on a ADSL Link Speed of 8128 kbps
Cheers,
Chris
Cheers,
Chris
Message 1 of 7
(1,416 Views)
6 REPLIES 6
Re: snr stats
19-05-2009 9:13 PM
On the surface they look OK.
Can you post the results of a BT Speedtest and http://www.mybroadbandspeed.co.uk
Message 2 of 7
(570 Views)
Re: snr stats
20-05-2009 9:00 AM
Hi and many thanks for your reply. I'm at work at the moment but I will post them up tonight when I get home..
Thanks again..
Chris
Thanks again..
Chris
Message 3 of 7
(570 Views)
Re: snr stats
20-05-2009 10:09 AM
Hi Chris,
The SNR stats looks okay. It's not a profiling issue as we're profiling your line @ 7150Kbps.
Could you let us know where you're downloading from?
Message 4 of 7
(570 Views)
Re: snr stats
20-05-2009 7:40 PM
Hi again
Still slower than they've been before but not as bad as last night
I was downloading from www.amd.com, tonight I've tried that site again and it was around 125KB/sec, www.filehippo.com at 279 and this one http://www.nvidia.com/page/uli_drivers.html was about the same as amd..
Cheers,
Chris
Cheers,
Chris
Message 5 of 7
(570 Views)
Re: snr stats
21-05-2009 3:10 AM
Speedtest.net is not the most reliable of speedtesters.
You can check on expected maximum speeds here - http://www.plus.net/support/broadband/quality_broadband/speed.shtml
If you could do that preferably at an off-peak time (early morning) and post the results.
Quote from: adiewoo On the surface they look OK.
Message 6 of 7
(570 Views)
Re: snr stats
26-05-2009 10:12 AM
Message 7 of 7
(570 Views)
