snr reset
will2012
snr reset
Please could you reset my snr?
Thank you
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: snr reset
I can complete an SNR Reset for you but before I do, can I ask why you would like it resetting?
Chris Pettitt
Cloud Environments Engineer
will2012
Re: snr reset
Because my speed is suffering given the current margin
Fixes: 46
Re: snr reset
Sorry, we don't perform SNR resets on request I'm afraid as we need to get to the bottom of what's caused the SNR to drop/rise so I'm going to advise raising a fault instead at this stage: http://faults.plus.net
Adam
 Adam Walker
will2012
Re: snr reset
I have contacted you privately, but have not received a reply.
Fixes: 46
Re: snr reset
Sorry will2012 A busy day in the forums means I've not been able to look at them until now.
Please don't think we're singling you out for any reason. All to often we're seeing requests for SNR resets where they're not needed, in some cases this can even cause further issues rather than be helpful.
As mentioned we'd rather get to the bottom of why the SNR might be low (i.e there may well be, as there is in many cases an underlying fault) before we'd like to consider performing one.
Adam.
 Adam Walker
will2012
Re: snr reset
Thank you for your reply.
There is no fault on the line. I caused the issue doing exactly the same as someone else on here was doing recently,as I mentioned in my pm, and for them their requested snr reset was easy enough. I am not exactly sure which other conclusion you wish me to draw.
Fixes: 46
Re: snr reset
OK, I'll submit an SNR reset for you. We have to be careful with submitting these. Not that I'm accusing you of this but I'm aware that it's easy to misunderstand why and when an SNR reset is appropriate.
Adam
 Adam Walker
will2012
Re: snr reset
Thanks very much for your help
