snr reset
- Re: snr reset
snr reset
29-11-2013 2:29 PM
could i request a snr reset please and can you confirm im still on fastpath........thnxs
Message 1 of 9
(1,071 Views)
8 REPLIES 8
Re: snr reset
29-11-2013 4:20 PM
Hi, yes you're still opted out of interleaving so still definitely on fastpath. Just wondering why the SNR reset though, as the line looks pretty good at the moment? While the speeds are fluctuating slightly (+/- 200k on the downstream) what's being lost on the downstream seems to be being gained on the upstream side of things?
Message 2 of 9
(623 Views)
Re: snr reset
29-11-2013 5:03 PM
Link Information
Uptime: 0 days, 3:21:51
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,267 / 14,023
Data Transferred (Sent/Received) [MB/MB]: 15.65 / 64.86
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 14.4 / 27.5
SN Margin (Up/Down) [dB]: 5.8 / 12.1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 137 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 19 / 160
HEC Errors (Up/Down): 35 / 863 as you can see 12db now as it was always 6db i was using a tp link w8968 previously which was faulty.........
Message 3 of 9
(623 Views)
Re: snr reset
29-11-2013 6:54 PM
Quote from: sully72 Link Information
<snip>
<snip>
I suspect this may be a reporting error, and the (Up/Down) is the wrong way round.
Message 4 of 9
(623 Views)
Re: snr reset
29-11-2013 7:02 PM
I assume those stats are from a 582n, and the upstream margin can be low with an uncapped upstream.
Message 5 of 9
(623 Views)
Re: snr reset
02-12-2013 9:28 AM
I've reset your SNR, although the target was at 9db already so it's not going to make a huge difference.
Message 6 of 9
(623 Views)
Re: snr reset
02-12-2013 3:00 PM
thanks for that, but my ip profile now seems a bit low
Uptime: 0 days, 5:03:46
Bandwidth (Up/Down) [kbps/kbps]: 1,247 / 17,843
Data Transferred (Sent/Received) [MB/GB]: 254.67 / 2.92
Output Power (Up/Down) [dBm]: 12.6 / 0.0
SN Margin (Up/Down) [dB]: 5.8 / 6.1
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 2,724 / 0
CRC Errors (Up/Down): 14 / 181
HEC Errors (Up/Down): 29 / 1,133
Message 7 of 9
(623 Views)
Re: snr reset
02-12-2013 3:16 PM
You're syncing at 17843, so your profile should be around 15700.
The profile in our system now matches this, if you're not seeing the speeds then you might want to log in to the router and do a single disconnect/reconnect.
Message 8 of 9
(623 Views)
Re: snr reset
02-12-2013 4:48 PM
all sorted now...........thanks
Message 9 of 9
(623 Views)
