snr reset please
lenny
snr reset please
hi
could i get a reset of my snr to 6 please Smiley
Fixes: 162
Re: snr reset please
On a line with the attenuation yours has (63.5db) I'd like to see some stability before lowering the SNR, I mention that as we saw a burst of disconnections earlier today:
If the line is stable for 24 hours or so then that would give us a better place to go from.
 Chris Parr
 Plusnet Staff
lenny
hi
the disconnects where due to thunderstorm and me swapping a router
lenny
Hi
any chance of a reset now please
lenny
Just been told my line seams stable now and no disconnects , so can I have my snr reset please Smiley
lenny
been moving cables and tried a different router , any chance of that reset please.
and the wifes just informed me she has used that vibro machine again , knocking my snr all aver the place Angry, going to cut the plug off it Grin
Fixes: 162
What's the latest lenny? Do you want me to reset it or do you want to try and sort the equipment causing the problem first? Keep in mind that we can only do SNR resets once every 10 days.
 Chris Parr
 Plusnet Staff
lenny
Could I have a reset please , the problem machine has been sorted Smiley
lenny
could we hold fire on the line reset please as i have the crackling and static hiss back on my line this morning , i have posted in the phone section
edited after phone fault check
please do the test again as the results of your line test are unclear, tied to do again and now comes up problem please phone plusnet and the number to call
lenny
engineer now booked for wednesday morning ,
what does this mean please
Fault Type: NOise
Test Results:TR0000004758445
Fault Ref: Failed diag
lenny
could i get the reset now please  Smiley
open reach engineer has just left , reports from him was that there was a problem with a line from the exchange to the cabinet that he has sorted , so hopefully that's an end to my problems for now Smiley
thanks
Fixes: 205
I've requested that for you now.
It should be done in the next 4 hours or so.
 Matthew Wheeler
lenny
thanks
lenny
still having problems ,
is it best to post them here or start a new thread ?
Fixes: 135
Post here so all info is together in one place.
Customer and Forum Moderator.
