slowing down and down
- slowing down and down
25-10-2008 2:12 PM
Re: slowing down and down
25-10-2008 2:39 PM
25-10-2008 2:51 PM
If that doesn't work what does this say https://portal.plus.net/my.html?action=data_transfer_speed
25-10-2008 5:40 PM
25-10-2008 5:42 PM
25-10-2008 9:28 PM
25-10-2008 9:41 PM
25-10-2008 9:46 PM
Runs all the way through, and gets to 96%, and stops. Tried with Firefox, and IE as well. Running XP SP3.
25-10-2008 9:56 PM
2) have you tried it with the 217. 35 code as apparently it stopped working with www.speedtester.bt ; but does work with http://speedtester.bt
I know its a pain, mine did stop working for a week recently for the above reasons.
26-10-2008 7:54 AM
I raised a query and got the usual circular responses. They even suggested it might be in my wireless setup - problem is I don't have a wireless setup! I've given up on support and my hope is that the complaints will eventually prompt them to fix it. Web browsing is unusable at times, with responses measured in mins. This morning 26/10/2008 @ 07:00-07:45 has been very slow at times. Clicked refresh, went off and made some coffee and site still hadn't responded, tried others UK, Europe and US and all the same.
These are my speedtest results:
Speed Tests
2008-10-04 @ 21:15
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 7616 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 6500 kbps
Actual IP throughput achieved during the test was - 3858 kbps
2008-10-05 09:50
Actual IP throughput achieved during the test was - 932 kbps
2008-10-13 09:50
download 159kbps
upload 149kbps
2008-10-13 09:55
Actual IP throughput achieved during the test was - 1018 kbps
26-10-2008 8:14 AM
Your DSL connection rate: 8096 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7000 kbps
Actual IP throughput achieved during the test was - 6136 kbps
dont know what your problem is. A good workman never blames his tools - he sorts out the problem
26-10-2008 9:45 AM
26-10-2008 9:46 AM
Whose thread is this?
Which problem is being looked at?
26-10-2008 9:49 AM
26-10-2008 11:19 AM
Fwiw my speeds have been very consistently back to their best for about a week; sort of assumed everyone else's had done the same
