slower than expected
timandjen2010
I should be getting according to my plusnet (Unlimited Fibre Extra) account; Estimated download speed: 54 - 61Mbps.
I am currently getting 16mps.
My wife & I both work from home, it is difficult at times and frustrating to not get anywhere near the speed we should get.
Tim
2 REPLIES 2
Fixes: 387
Re: slower than expected
Welcome to the forums @timandjen2010
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
SammyM
Fixes: 101
Hiya @timandjen2010,
I'm sorry you are having an issue with your speed and for the hassle this will be causing you.
I have run a test on the line and the speed is showing as within estimates from our side and no faults are appearing on the line.
Can I just check the speed test you run, was that on a wired or wireless connection?
 Sammy M - Sheffield Team
