slower speeds and higher pings "RESOLVED"
- slower speeds and higher pings "RESOLVED"
Re: slower speeds and higher pings "help needed"
23-10-2012 10:29 AM
23-10-2012 11:11 AM
Virtual paths: Green
There are currently no known capacity problems on your exchange. There may still be an exchange problem, however BT are not currently reporting that they are aware of it. Please contact Support if you are having speed problems, who can advise further.
Record last updated: 19 Oct 12
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Link Power State: L0
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1 dB): 85 287
Attenuation (0.1 dB): 320 138
Output Power (0.1 dBm): 0 121
Attainable Rate (Kbps): 11940 1080
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 10177 444 0 0
MSGc (# of bytes in overhead channel message): 59 10 0 0
B (# of bytes in Mux Data Frame): 158 63 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 2 1 0 0
R (# of check bytes in FEC Data Frame): 12 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.4983 4.5309 0.0 0.0
L (# of bits in PMD Data Frame): 2745 113 0 0
D (interleaver depth): 64 1 0 0
Delay (msec): 7.97 1.13 0.0 0.0
INP (DMT symbol): 1.11 0.0 0.0 0.0
Super Frames: 4148863 4757 0 0
Super Frame Errors: 0 0 0 0
RS Words: 539352230 0 0 0
RS Correctable Errors: 21216586 0 0 0
RS Uncorrectable Errors: 220734 0 0 0
HEC Errors: 4294967289 43651 0 0
OCD Errors: 37 0 0 0
LCD Errors: 0 0 0 0
Total Cells: 1612785290 770023 0 0
Data Cells: 6995355 35878 0 0
Bit Errors: 0 0 0 0
Total ES: 4120 0
Total SES: 1326 0
Total UAS: 84 4294967213
Bt speed test also shows ...
Download speedachieved during the test was - 6.72 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 8.98 Mbps
Upload speed achieved during the test was - 0.38Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Estimated line speed:8Mb (This may vary between 5.5Mb and 12.5Mb) - Checked on 2012-09-19 01:42:46Current line speed: 7.6 Mb ( plusnet account )
As it stands my connections shows as faster and better ping but even now when i load pages they are slow to load, the worst to load is bbc.co.uk news site which is my homepage.
Another thing i dont understand is all these stats/reading show me having different IP profiles daily, is that normal ?
23-10-2012 11:35 AM
23-10-2012 11:37 AM
23-10-2012 2:50 PM
To the second point, Download speed is affected by a number of things which can be broadly divided up simplistically as follows -
1) Your connection speed to the exchange 2) Exchange congestion 3) ISP Network & congestion 4) Traffic management 5) www hops from ISP to 6) Site/server being visited
1) Because of some previous event/line quality, your current Target noise margin seems to be 9dB. If the line is stable then this will drop with a further improvement in speed.
2) Just sorted, so hopefully you will see better speed and ping more of the time
3) No known problems likely to affect you
4) Download sites, FTP, Usenet and suchlike have speed restrictions at certain times dependant on your package. Normal web browsing is not restricted.
5) Depends on routing, over which there is little/no control
6) Totally down to the site you visit.
The BBC news site is not especially fast. All speeds can be slow at any instant dependant on congestion at that instant anywhere between you and the site in question. Servers on some sites have low speed/capability.
jelv's point wasn't a suggestion to resync (please don't - we need to see stability) it was a statement about how it works,
HTH.
23-10-2012 4:55 PM
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Downstream Upstream
SNR Margin (0.1 dB): 84 287
Attainable Rate (Kbps): 11676 1004
Path 0 Path 1
Super Frames: 5417110 212455 0 0
RS Words: 704224314 0 0 0
RS Correctable Errors: 25229884 0 0 0
RS Uncorrectable Errors: 260851 0 0 0
HEC Errors: 4294967289 53751 0 0
LCD Errors: 0 0 0 0
Total Cells: 2105825477 604080 0 0
Data Cells: 9939665 4425 0 0
Bit Errors: 0 0 0 0
Total ES: 4679 0
Total SES: 1623 0
System Running time: 1 day(s) 19:31:42
Shows an improvment but loading almost all webpages takes 30 sceonds or more could this be a java or flash problem maybe ?
23-10-2012 5:57 PM
23-10-2012 6:49 PM
This last BT speedtest suggests you've had a resync and the speed is now around 10986.
23-10-2012 6:58 PM
Third, Adam Walker should have updated your current line speed to 8.97 to match the profile that should have been there earlier, and he hasn't, so the speed should have been a bit better.
4th. The speedtest.net server could be congested. After you've done the stats and BT speedtest and posted them, try another speedtest.net, if bad try another server eg. Milton Keynes.
5th, That poor BT speedtest should have given you the option to conduct further tests, we may consider that.
It's possible there may still be congestion at the exchange despite the updated VP status, we may have to test more.
23-10-2012 7:03 PM
Line Rate - Upstream (Kbps): 443
Line Rate - Downstream (Kbps): 10983
LAN IP Address: 192.168.1.1
Default Gateway: 195.166.128.185(pppoa0)
Primary DNS Server: 212.159.6.10
Secondary DNS Server: 212.159.6.9
System Running time: 1 day(s) 21:43:43
I dont understand it ?
IS it my line or my router? im at a loss
23-10-2012 7:03 PM
Try to avoid peak periods, such as when the kids have been fed and they are doing their "homework".
23-10-2012 7:11 PM
Maybe i need to try a new router?
I currently have a ticket in with support and im told they cant find any issues, but my recordings and the graph posted my adam in these forums clearly show problems.
I feel i need more answers as im at a loss here!
23-10-2012 7:16 PM
23-10-2012 7:20 PM
23-10-2012 7:38 PM
I'll post back in a moment with some different tests. But try the speedtest.net ones again and also the BT beta one (don't take too much notice of it's ping if slow).
