slower speeds and higher pings "RESOLVED"
- slower speeds and higher pings "RESOLVED"
Re: slower speeds and higher pings "help needed"
27-10-2012 8:46 PM
27-10-2012 9:45 PM
Here is a graph showing your connection for the past week:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13513706379085.png" />
27-10-2012 9:47 PM
28-10-2012 8:33 AM
To summarise the above, there are only two (possibly 3) unexplained drops, the rest are all user initiated, either re-boots due to what appears to have been issues with the old modem/router or installing new equipment and settings changes.
The disconnect Thursday ~2000 I wonder if it was you rebooting, but there was no post or PM to say, so not sure.
The disconnect showing on Friday ~1700 could have been you changing the modem/router although you did this just after 1500 there was no disconnect showing then and there was no drop at ~1700 that you knew or made me aware of. Later was dealing with wiring after which no loss of sync, just session disconnect/connect.
On Saturday, when you had the extensive interference on the radio, there was no drop (that may in the main be a good sign) but we don't know what happened with the error rate and then there was this unexplained drop at ~1600 when your connection was banded.
The only other unexplained drop was on Tuesday 23rd ~1700. Now I have reviewed the thread & my PMs, I sent Adam a PM at 1637 pointing out that the Current Line Speed hadn't updated in over 40 hours, could he give it a kick. We didn't notice any change, but at ~1800 a BT speedtest had a throughput result of 2.22Mbps and the next day when I posted reply #73, Adam replied Reply #79
Quote It depends what you mean by kicked, as the profile on our systems was in line with the IP profile (which was well below the actual synch speed) I took that as meaning an SNR reset.
So I'm actually wondering if the Line was indeed reset and it is in training. This may explain why Chris couldn't find the bRAS profile Friday night and the drop Saturday was due to DLM messing. Perhaps someone from Plusnet can confirm if the line is in training.
Whatever is actually happening, I need to remind you of my reply #99, this will be far more important if the line is in training.
Also you need to finish sorting out your internal wiring as per PM. (I'll send you a PM later today.).
28-10-2012 11:34 AM
28-10-2012 11:42 AM
PM will be later today. You know what to do in the mean time
28-10-2012 11:48 AM
Bt speed test site keeps showing as busy for me so this current speedtest will have to do.
28-10-2012 12:30 PM
28-10-2012 1:19 PM
btw this has changed in my login again
Estimated line speed:8Mb (This may vary between 5.5Mb and 12.5Mb) - Checked on 2012-10-25 21:24:28Current line speed: 8 Mb
I had to unplug the router from phone line before while i removed the upstairs bell wire.
29-10-2012 11:23 AM
29-10-2012 3:22 PM
One thing I will remind you of is my reply #99 again. As you haven't been following that method that may have contributed to the banding and if you don't follow it DLM may band you at a lower speed which won't be so clever.
I see no-one from Plusnet has picked up on my reply #138 yet, especially
Quote from: Anotherone The only other unexplained drop was on Tuesday 23rd ~1700. Now I have reviewed the thread & my PMs, I sent Adam a PM at 1637 pointing out that the Current Line Speed hadn't updated in over 40 hours, could he give it a kick. We didn't notice any change, but at ~1800 a BT speedtest had a throughput result of 2.22Mbps and the next day when I posted reply #73, Adam replied Reply #79
Quote from: _Adam_Walker_ It depends what you mean by kicked, as the profile on our systems was in line with the IP profile (which was well below the actual synch speed) I took that as meaning an SNR reset.
29-10-2012 3:37 PM
30-10-2012 10:39 AM
30-10-2012 10:47 AM
30-10-2012 11:00 AM
