slowdown at BNG?
- slowdown at BNG?
slowdown at BNG?
05-07-2015 11:58 AM
I'm a new customer, and my line speeds seem fine, but I'm getting a lot of latency, and it appears to be at/beyond my cabinet:
the best case pings look great (12ms or so), but I often get hit with 500-1200ms!
this really makes working from home difficult.
any chance this could be looked into?
some example MTRs:
[tt]
Start: Sun Jul 5 11:42:52 2015
HOST: smcghee-macbookair2.xxxxxxxxx Loss% Snt Last Avg Best Wrst StDev
1.|-- dsldevice.lan 0.0% 10 2.8 6.0 2.3 29.5 8.3
2.|-- lo0.11.central11.pcl-bng02.plus.net 0.0% 10 16.1 241.5 11.9 712.8 284.1
3.|-- irb.11.pcl-cr02.plus.net 0.0% 10 12.2 235.7 12.0 711.8 266.6
4.|-- ae1.ptw-cr02.plus.net 0.0% 10 13.9 190.3 12.9 644.2 252.5
5.|-- ae2.ptw-cr01.plus.net 0.0% 10 230.0 172.7 11.8 585.2 222.8
6.|-- 72.14.222.97 0.0% 10 120.8 209.9 13.6 675.9 243.7
7.|-- 209.85.246.242 0.0% 10 63.3 174.8 13.1 622.8 219.2
8.|-- 216.239.51.233 0.0% 10 74.4 143.2 14.0 535.2 183.9
9.|-- lhr14s27-in-f78.1e100.net 0.0% 9 31.7 98.9 11.7 508.0 167.4
1.|-- dsldevice.lan 0.0% 10 3.0 4.8 2.1 20.8 5.6
2.|-- lo0.11.central11.pcl-bng02.plus.net 0.0% 10 12.1 139.1 12.1 629.5 212.1
3.|-- irb.11.pcl-cr02.plus.net 0.0% 10 756.0 225.4 11.8 756.0 264.1
4.|-- ae1.ptw-cr02.plus.net 10.0% 10 58.0 142.7 12.5 489.9 162.9
5.|-- ae2.ptw-cr01.plus.net 10.0% 10 263.1 147.4 12.5 490.9 155.9
6.|-- 72.14.222.97 10.0% 10 209.8 126.3 13.2 474.0 145.8
7.|-- 209.85.246.242 10.0% 10 135.4 97.3 12.0 438.9 136.4
8.|-- 216.239.51.233 10.0% 10 55.7 83.0 11.8 477.0 149.4
9.|-- lhr14s27-in-f78.1e100.net 10.0% 10 15.3 77.1 12.0 482.8 153.7[/tt]
some example MTRs:
[tt]
Message 1 of 6
(1,048 Views)
5 REPLIES 5
Re: slowdown at BNG?
05-07-2015 12:20 PM
I believe this is bufferbloat. If I upload anything, the latency gets terrible.
also:
http://www.dslreports.com/speedtest/801898
related, I currently have an Airport Extreme attached to the Sagemcom F@ST2704N modem/router.
I would prefer to have just a single router, but the sagemcom doesn't seem to be able to be put into modem-only mode 😕
also:
Message 2 of 6
(628 Views)
05-07-2015 12:55 PM
If you have a "previous ISP modem/router", use that in bridge mode instead.
Phil
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 3 of 6
(628 Views)
16-07-2015 3:00 PM
an update, I'm now using PPPoE/PPPoA via a DrayTek modem in bridged mode, so that should reduce the confusion of having two routers in a row.
That said, I still see bufferbloat on uploads:
HOST: smcghee-macbookpro2.roam.co Loss% Snt Last Avg Best Wrst StDev
1.|-- 10.0.1.1 0.0% 10 16.7 3.6 1.1 16.7 4.7
2.|-- lo0.11.central11.ptn-bng0 0.0% 10 12.9 13.0 10.0 23.5 3.9
3.|-- irb.11.ptw-cr01.plus.net 0.0% 10 11.9 11.3 10.3 13.4 0.7
4.|-- 72.14.222.97 0.0% 10 11.2 12.4 9.8 16.0 2.1
5.|-- 209.85.246.244 0.0% 10 20.2 13.6 10.3 20.2 3.6
6.|-- 209.85.250.171 0.0% 10 10.8 13.5 10.5 24.7 4.5
7.|-- lhr08s05-in-f14.1e100.net 0.0% 10 11.0 12.0 10.1 13.8 1.1
smcghee-macbookpro2:~ smcghee$ mtr -tr google.com
Start: Thu Jul 16 14:59:11 2015
1.|-- 10.0.1.1 0.0% 10 1.3 3.5 1.1 13.8 3.8
2.|-- lo0.11.central11.ptn-bng0 0.0% 10 480.1 289.8 19.0 578.6 188.1
3.|-- irb.11.ptw-cr01.plus.net 0.0% 10 500.8 280.1 11.1 556.8 184.0
4.|-- 72.14.222.97 0.0% 10 531.5 269.6 23.8 531.5 175.1
5.|-- 209.85.246.244 10.0% 10 298.3 237.1 10.7 494.8 175.3
6.|-- 209.85.250.171 10.0% 10 293.1 240.1 14.0 479.6 167.6
7.|-- lhr08s05-in-f14.1e100.net 10.0% 10 409.8 261.7 11.3 493.5 171.5
Message 4 of 6
(628 Views)
16-07-2015 3:03 PM
i forgot to add:
http://www.dslreports.com/speedtest/870757
Bufferbloat: D (where F is the worst)
<a href="http://www.dslreports.com/speedtest/870757">
<img src="http://www.dslreports.com/speedtest/870757.png"></a>
Message 5 of 6
(628 Views)
16-07-2015 3:44 PM
bufferbloat on uploads will happen without QoS at your end.
Message 6 of 6
(628 Views)
