slow upload- is this normal?
lollipop1
Morning,
I just did a line test this morning.
Can anyone tell me is this normal?, it seems very slow speed.
My PC is always connected by ethernet directly into the router, which is about a foot away from the main box.
4 REPLIES 4
Legend
Fixes: 255
Re: slow upload- is this normal?
Welcome to the forums, @lollipop1 - that upload speed is actually very good for an ADSL connection, you would struggle to get very much more.
lollipop1
Thanks for your reply, maybe time to move onto fibre....
Legend
Fixes: 255
Check what you would get on fibre - if you really need a much higher upload speed and stay with Plusnet, you will need the 80/20 package, which is considerably more than you are paying for ADSL.
Fixes: 1,600
I'd agree. The upload speed you're getting is looks to be as much as you can get for your connection.
Fibre would be a big step up, as your upstream estimates are 19-20mbps.
