slow traffic through 195.166.128.53
Robtheplod
hi all, anyone else getting poor vpn response (200ms+) when both sides connect to the above gateway?? if i'm lucky and get another gateway then this goes down to 30ms...
1 REPLY
James
Re: slow traffic through 195.166.128.53
hi there,
sorry to hear that you're having problems.  I've just had a look at all of our gateways and can't see anything that would causes problems such as those you are experiencing.  Have you tried rebooting your router and seeing if the performance improves?
