slow speeds for a week
graycbr
hi been with plusnet for a few yrs now , now having really slow speeds now & now & then it drops connection . Just took 30 mins to load this page .. Cant do a speed test takes to long to load page .. Plugged into master test socket no increase in speeds .. Plugged laptop into router direct no increase in speed .. Had engineer around around 5-6 times now ,had a new master socket installed direct from outside wiring etc last time .. Been a week now at this speed plz help ASAP
Fixes: 184
Re: slow speeds for a week
Could you drop me a PM with the account username so I can check what's been happening with this.
Thanks.
 Harry Beesley
graycbr
Pm just sent
Fixes: 184
Thanks for the PM, apologies I didn't get back to you before the weekend.
Testing your line seems fine and isn't flagging up much of concern:
General Information
NTE Status:   NTE Power Status: PowerOn Bypass Status:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 5.3 12.5
SNR Margin: 6.5 3.1
Errored Seconds: 0 0
HEC Errors: 0
Cell Count: 18491753 3498
Speed: 1183 21583
However I can see your connection is dropping out excessively:
I'm going to increase the target SNR from 3db to 6db to try and stabilise the connection, could you let me know if you continue to experience problems after a few hours.
Thanks.
 Harry Beesley
graycbr
Hi
Still the same speed is painfully ,sorry to say
graycbr
So slow
Fixes: 184
Sorry to hear that.
Are you still using the Thompson Technicolor TG582n router that we provided a few years ago?
Do you hear any noise on the phone line if you dial 17070 go follow the option for the quiet line test?
Was this with your phone provider as opposed to a broadband fault report? As I notice from your account no fault has been reported in quite some time.
 Harry Beesley
graycbr
hi No using the Netgear N600 ADSL2+ Modem router .Your router was faulty BT engineer said so brought this one on the second visit . No noise when dial 17070 No Broadband Faults with all engineer visits ,guessing last time hear 3-4 mths ago
graycbr
NETGEAR DGND3700 V2 router N600 .. Still slow just done a firmware update as well , rebooted system unplugged everything & turned everything off which uses a internet signal .. Just got one device on setup & still slow ... 15 mins to load this page & loads of refresh's as well ....
graycbr
Hi
Can you reply as now getting fed up now , paying for a service & not receiving .
Fixes: 162
Your line is still disconnecting a lot.
If that was from the engineer in June, they really shouldn't be supplying you with random routers and looking at the notes they say a fault was fixed on the line rather than an issue with the router itself:
Engineer notes: Hr (high resistance) on obsolete lead
 I'd advise getting this reported to us as a fault at https://faults.plus.net
 Chris Parr
 Plusnet Staff
graycbr
Hi
You've read that wrong I stated the second visit not the fifth visit which was June !!!
Plus the bt engineer did not supply me with a router !! Advised me the one I had was faulty at the time ..
The last visit was a new master socket installed due to wires outside faulty , so I had the best setup coming inside the house as the original wires was past there best !!
