slow speed
- Re: slow speed
slow speed
28-07-2011 12:33 PM
i usually turn my router off when I do not use it as before moving to plusnet I was on an LLU so always got my half meg (I live a long way from my exchange, :-[) Anyway i am aware that turning it off regularly can make BT/Plusnet thinking im getting disconnects and thus reduce my speed, so i have left it on for the last 3 days but my download speed is still terrible, less than half a meg infact!
Could someone at plusnet take a look, i'm not expecting miracles i reckon somewhere near half a meg is not to mush to ask, you did manage it when I first signed up.
Cheers and all the best
Did
Re: slow speed
28-07-2011 3:21 PM
I've checked your account and have runs some diagnostics. It looks like a speed profile of 135kbps is still in place due to the previous disconnections/router being powered off.
I'm going to perform an SNR reset which should resolve this within a couple of hours for you all being well.
Adam
Re: slow speed
28-07-2011 3:26 PM
Just to add to the above, you're fine to disconnect the router at night - just drop the connection via the router's interface before you power it down and it won't be seen as a forced disconnect by the exchange.
Hope that helps,
Re: slow speed
29-07-2011 1:31 AM
Thanks for the replies, speed is at 232kbps so a slight increase.
Regarding dropping the connection via the routers interface I have a Netgear DG834G and I can login to it and then seem to be able to disconnect it via a connection status button, I have just done this at 01:25 ish, did this show as a forced disconnect?
Many thanks
Did
Re: slow speed
29-07-2011 1:41 AM
Re: slow speed
30-07-2011 7:26 AM
Cheers
Did
Re: slow speed
01-08-2011 12:55 PM
I've just tried ringing you so I could ask you a few questions about your connection. Your profile has not been above 350 since you started but I would have expected better. Let me know when you're available.
Jojo
Re: slow speed
02-08-2011 9:10 PM
Sorry I'm at work during the day and available until 7pm but have most Fridays off if that helps?
Many thanks
Did
Re: slow speed
02-08-2011 9:18 PM
also my router shows that im connected at a faster speed than i am actually getting, im still getting 232 kbps.
Modem Status Connected
DownStream Connection Speed 421 kbps
UpStream Connection Speed 439 kbps
VPI 0
VCI 38
Did
Re: slow speed
03-08-2011 11:43 AM
Your current sync rate is 421k, this will bring your profile back up to 350k, but that can take 72 hours or so. I'll give you a call on Friday and we can take it from there. Give me a nudge though and let me know when it's convenient.
Jojo
Re: slow speed
05-08-2011 7:26 AM
Many thanks
did
Re: slow speed
05-08-2011 8:07 AM
Seems I'm lucky to get any speed at all.
Did
Copper Line Test
Circuit ID: CBUK82231447 Service ID: BBEU02685766
Telephone NO.: N.A. Test Executed On:
Status: Pass MFL: OK OR Test ID: hws044a001:154947660
Test Outcome: Line Test OK - End User Equipment detected
Copper Test Details
A to E B to E
Capacitance: 363 NanoFarad 372 NanoFarad
DP Line Length Estimate: 18496 Metres DN Line Length Estimate: 18579 Metres
Celerity: 72.9 dB Line Loss:
Fault Report Advised: N
Service Level: 2
Extremely long line, suprised this line can support broadband at all.
Re: slow speed
05-08-2011 8:24 AM
That attenuation is rancid though, which explains the 0.5meg.
When we first got BB, it was 512K and you had to be within 5km of the exchange for it. my line (all copper) was 4.80km. BT provided us with service, when we migrated to plusnet they cut us off, and said our line was "not fit for broadband" (sour grapes at losing a customer i feel 😉 )
Quote it seems my phone line is 18.5 km long.
I would suggest that this is a false reading tbh, quite possible because its so long its messing up the result.
Regards
Re: slow speed
06-08-2011 7:32 AM
Best wishes
did
