slow speed - SNR Margin reset request
- slow speed - SNR Margin reset request
- « Previous
- 1
- 2
- Next »
Re: slow speed - SNR Margin reset request
28-08-2019 9:40 AM
Something seems to have changed, although as far as I know the phone line fault hasn't been fixed yet.
The Margin now seems to have been reduced to 15, and the router is reporting a better speed, although a speed test is still very slow.
6 - Uptime: | 1 days 02:17:39 |
7 - Data rate: | 1077/7392 |
8 - Maximum data rate: | 1084/7992 |
9 - Noise margin: | 6.1/15.0 |
10 - Line attenuation: | 19.6/38.5 |
Message 16 of 17
(261 Views)
28-08-2019 11:37 AM
Hi @phil_the, thank you for the update.
Our suppliers are still investigating the phone fault as you know. Once this is fixed, we will then be able to look properly look into the broadband connection for you.
Message 17 of 17
(249 Views)
- « Previous
- 1
- 2
- Next »
