slow slow slow
mac
slow slow slow
what's happened to my speed over the last few days  133-144-133 kbps.
Re: slow slow slow
If you are expecting some advice or help then you are going to have to supply a lot more information...
Results of any speed tests
Results of the BT speedtest
Line stats from your router
What were you getting previously
Have you tried connecting direct to the master socket without any phones connected
Are all phone connected via filter/splitter
Re: slow slow slow
You'd need to give more info for anybody to give you a useful answer I'm afraid.
What speeds did you get before?
Has anything changed?
Describe your setup a little:
Have you tried anything to improve your speeds recently?
mac
Re: slow slow slow
my usual speed is about 4000kbps
nothing changed
modem hard wired voyager 105.
all filters in place
Re: slow slow slow
Still need full details of BT speedtest and some other speed tests like www.mybroadbandpseed.co.uk
We also need your line stats
mac
Re: slow slow slow
Last Result:
Download Speed: 133 kbps (16.6 KB/sec )  Upload Speed: 77 kbps (9.6 KB/sec )
results for broadband max
mac
Re: slow slow slow
how do i give line stats
i have dsl debug open giving details
Re: slow slow slow
The link I gave explains how to find them. Just scroll down on that page to the 105 and click on the link.
Then post the line attenuation & SNR (margin) figures for up and down.
We still need the BT speedtest results which are they key to understanding what may have happened.
mac
Re: slow slow slow
yes as i said i got then in font of me how do i post them
Re: slow slow slow
Just type them into a post reply  Huh
mac
Re: slow slow slow
sorry am a bit slow with this as i have not ever done this before
ok i think what you what i hpoe is the reading 6272 up 448 down
trying to get bt test but the 1st test was so slow its asked to change logon to bt test
mac
Re: slow slow slow
ok i did a bt test and i gave my correct tel number and i mean correct number and it said i appear to be log in as steve something at virgin.com
and is asking to change modem log in to bt test
Fixes: 9
Re: slow slow slow
Quote from: mac
Huh
Can you go to http://usertools.plus.net/@gateway and tell us what it says please. It should say something like
You are currently connected to the "Telehouse North, Juniper 2" gateway. This gateway is sometimes known as ptn-ag2.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: slow slow slow
Its a PN IP he's posting from if thats what you are wondering Mr Jelv. Wink
Fixes: 9
Re: slow slow slow
That was what I was wondering - so where the devil has the virgin.com come from? Huh
