slow peer to peer ?
- Re: slow peer to peer ?
slow peer to peer ?
06-11-2007 2:01 PM
06-11-2007 2:06 PM
Could be the torrent you are trying, although you are connected to many seeds, they still may not upload very quickly.
Also, sometimes you need to watch how many seeds/peers you try and connect to, since a large number of open connections can slow down the connection.
This is because each packet recieved must be acknowledged by sending out what is known as an ACK packet.
Try lowering the number of max open connections, or try a different torrent to check that out. Perhaps from fedora.redhat.com. there torrents are always exceptionally fast!
06-11-2007 2:09 PM
06-11-2007 2:18 PM
You shouldn't be seeing speeds quite as low as that. Might be worth trying to reconnect to a different gateway to see if that resolves the issue, or it may be solely related to the seeds that you are connected to.
06-11-2007 2:19 PM
06-11-2007 2:21 PM
http://www.plus.net/support/broadband/products/archive/bb_premier1.shtml
06-11-2007 2:21 PM
06-11-2007 2:27 PM
06-11-2007 2:30 PM
06-11-2007 2:31 PM
Quote from: Chris Are you seeing 40kbps or 40KBs? I ask because the second one is around what we would expect on Premier between 12-2 as per this page.
I was always lead to believe that with a premier option 1 you were not restricted until 4pm. Seems i was wrong
06-11-2007 2:34 PM
Quote from: Chris That would explain it then P2P starts being slowed at 12 down to 448Kbps as per the previous page. Hope this helps.
man thats such a depressing speed, its not like ive got a 7000kbps line to make some time up when the restriction is lifted. Does my head in when ive got my pc on overnight cus i can hear it when im trying to get to sleep, even though its in another room
Might have to invest in some veg oil and submerge my pc like that bloke on youtube
06-11-2007 2:37 PM
