slow lagging connection :(
nicnicnic
just done a test
Best Effort Test:  -provides background information.
Download  Speed
1.49 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 1.49 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :4.26 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 3 Mbps
If you wish to discuss these results please contact your Broadband Service Provider.
If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit the FAQ if you are unable to understand the test results.
can someone please sort this out!!!!!!
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: slow lagging connection :(
Hi nicnicnic,
I'm sorry to hear that you're having issues with slow broadband speeds.
In the first instance I would certainly look at connecting an alternative micofilter ( http://www.plus.net/support/broadband/master-socket-guide.shtml ) and if the issue persists, connecting your equipment into your Test Socket ( http://www.plus.net/support/broadband/microfilters-how-and-why.shtml ).
If the problem persists, raise a fault at http://faults.plus.net and we'll get the problem looked into for you.
Chris Pettitt
Cloud Environments Engineer
