slow internet speed
- slow internet speed
Re: slow internet speed
18-06-2010 2:07 PM
29-06-2010 2:19 PM
29-06-2010 2:44 PM
I've just done a line test and it's showing as all sockets unplugged - is there a phone plugged in at the moment? I would assume so, and if there is then that result confirms the fault in which case I can get it raised for you.
30-06-2010 9:21 PM
25-07-2010 7:29 PM
£50 credit limit its a joke its up to me how many calls i make,i can spend that in a week. bye guys thanks for reading my thread dont let these guys take u for mugs.
25-07-2010 7:34 PM
25-07-2010 8:34 PM
25-07-2010 10:17 PM
25-07-2010 11:55 PM
26-07-2010 12:55 PM
Please let us know how it goes with Opal so we all learn something from this.
26-07-2010 4:23 PM
r.c.c.h
26-07-2010 5:41 PM
I'm sure there will be a correlation between noise on the phone line and poor speed of broadband. When I had a bad line last week (due to a bad contact) the connection was variable between a bit of noise and no dial tone. The better the audible connection, the faster my broadband.
Now that you can watch You Tube again, my favourite at the moment is this one,
, a parody that is better than the original!
27-07-2010 6:43 AM
27-07-2010 9:32 AM
Plusnet are actually part of BT but they have been allowed to maintain their own identity to provide a low-end, low-cost alternative to the standard BT Broadband offering. Despite this, they are not able to gain any leverage from being part of BT so, for example, they cannot get a BT Openreach engineer to simultaneously address a voice line fault and a broadband fault. The point I made earlier was that if you are unhappy with your Plusnet broadband speed then the worst thing you can do is switch to another non-LUU ISP. With an LUU ISP you are less beholden to BT and with Virgin cable you are not-at-all beholden to BT.
Personally, I'm very happy with my Plusnet service, which as just as well because I don't have a LUU or cable alternative.
28-07-2010 9:03 AM
another http://www.speedtest.net/result/894544800.png
