slow broadband connection
elkieluca
Ever since my phone and broadband were fixed last week the broadband connection is poor. Sometimes it won't open pages and its gone from 15mbs to 9mbs. When the engineer left it was still 15mbs but since then its got slower.
Can a staff member please look at this or should I open a ticket in support. Thanks.
All4One
Re: slow broadband connection
Connection via ethernet or wireless? If wireless sounds like an interference issue.
Those speed drops still shouldn't affect pages loading.
elkieluca
I think its both as its connected to a wire on my PC and it has WiFi too. I don't know much about it as you can tell.
Windoze tends to use wifi by default Crazy
Its best to disable wifi to make it use cable  Roll eyes
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
elkieluca
How can I disable WiFi when I use it for my tablet and kindle. I don't think that's the answer. Thanks.
Your speed profile was not aligned your sync rate so I've changed this for you, this will take effect in the next 10-15 minutes.
Let us know how you get on.
elkieluca
Ok thanks Chris.
elkieluca
Its fine now Chris almost 15 again 14.60mbs.  Also I can now open sites lilke IMDB and really fast. Thank you for fixing it.
no disable it on your computer  Wink
elkieluca
PeterLoftus,  I now see what you mean and I should have said that my computer has no wifi on it and that why its connected by ethernet.  Its fixed now so thanks for your input as it all helps me to understand things a bit more. Smiley
